Failure on DVD
Zontar
Failure on DVD
#1 Post by Zontar » Sat Oct 26, 2019 10:38 pm
This appears to be throwing a rod in libmakemkv. It is a DVD-R mastered by unknown forces.
I am running Fedora 31 and compiled everything on that os.
If you need more info, just ask.
Debug log started at Sat Oct 26 22:28:19 2019 , written by MakeMKV v1.14.5 linux(x64-release)
001005:0000 MakeMKV v1.14.5 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/alan/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at DQ9nw)2P[n[;fD|O&:121262325
001003:0020 DEBUG: Code 0 at YFtD3X-9|9] uR+}.:213132652
001003:0020 DEBUG: Code 0 at YFtD3X-9|9] uR+}.:213132928
001003:0020 DEBUG: Code 0 at YFtD3X-9|9] uR+}.:29393815
001003:0020 DEBUG: Code 0 at 8Z9')"E=^}]^lh_bh52\.=*:213130122
No  SDF v063: ATAPI_iHAS324___B_AL1A_3743524252_298133500035
SDF id v063: ATAPI_iHAS324___B_AL1A_3743524252_298133500035
No  SDF v063: ATAPI_iHBS212___2_5L09_3772512013_226125500342
SDF id v063: ATAPI_iHBS212___2_5L09_3772512013_226125500342
No auto SDF v063: ATAPI_iHBS212___2_5L09_3772512013_226125500342
DEBUG: Code 0 at lH]X/?PO~dv$@a$Ac:29395540
DEBUG: Code 0 at SL1N3W9YEAD03Q%;r:121261773
DEBUG: Code 0 at SL1N3W9YEAD03Q%;r:29393792
003028:0000 Title #1 was added (19 cell(s), 1:30:11)
005014:0000 Saving 1 titles into directory /home/alan/Videos/1984
002020:0000 Device '/dev/sr1' is partially inaccessible due to a bug in Linux kernel (it reports invalid block device size). This can be worked around, but read speed may be very slow.
001003:0020 DEBUG: Code 4294964528 at ?!$B{cz^fxI19*SO}S&T:213143002
001003:0020 DEBUG: Code 0 at ?!$B{cz^fxI19*SO}S&T:29404050
001003:0020 DEBUG: Code 0 at C$d$?PkO;MdgnwUj(OcE_:213136608
001003:0020 DEBUG: Code 0 at kVk?\"uKXlK&eUH(:29395908
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
004007:0010 AV synchronization issues were found in file '/home/alan/Videos/1984/title_t00.mkv' (title #1)
004008:0010 AV sync issue in stream 1 at 1:21:26.208 with duration of 32ms : broken timecode, apparent audio skew is -46.464s
004008:0010 AV sync issue in stream 1 at 1:21:26.272 with duration of 32ms : broken timecode, apparent audio skew is -46.432s
004008:0010 AV sync issue in stream 1 at 1:21:26.624 with duration of 32ms : broken timecode, apparent audio skew is -320ms
004008:0010 AV sync issue in stream 1 at 1:21:26.656 with duration of 32ms : broken timecode, apparent audio skew is -288ms
004047:0010 AV sync issue in stream 0 at 1:20:40.068 : video frame timecode differs by -46.179s
005003:0000 Failed to save title 0 to file /home/alan/Videos/1984/title_t00.mkv
005004:0080 0 titles saved, 1 failed
Zontar
Re: Failure on DVD
#2 Post by Zontar » Mon Oct 28, 2019 1:47 am
I recompiled using the current ffmpeg source and libfdk-aac. Same results.
