Okay, guys! Just a quick update...Mat1926 wrote: ↑Mon Jul 30, 2018 5:06 pmThis method did not work for me. The issue is the "CloseFile" operation, it is not in the drop down menu, and typing "CloseFile" does not help...
The only way was a tutorial on YouTube using ProcessMonitor + PowerDVD + filtering Path only "mpls"...This lead to the correct play list... and then I used makmkv to extract that one only...
The method I described above (not mine BTW), is the perfect starting point. It saves you a lot of trouble if you have many playlists, because you don't spend time searching for the correct playlist if you followed the OP method. And searching for .mpls instead of .m2ts served me well until last night!
I have this BD where the correct .mpls according to M$ Process Monitor does not show entirely in the MakeMKV list. So I thought of giving the .m2ts method a go...and guess what as expected I was able to find the correct playlist. However, maybe it is because I am on Win 10 X64, or because my Process Monitor is the latest, the only difference is that instead of "CloseFile", choose "IRP_MJ_CLOSE" from the combo box/drop down menu. That is the only difference...
Good luck, and thnx to OP for the help
