Avengers Endgame
ncarusojr
Avengers Endgame
Post by ncarusojr » Fri Oct 25, 2019 1:59 am
I just got Avengers endgame and the disc keeps ejecting when I try and load it. I have the latest update 14.5. I put the disc in my blue ray drive it spins it up and then ejects it. The disc played fine in a blue ray player and I tried other discs on my Mac and blue ray drive and they all read fine. Any help would be appreciated. I have no logs because it just spins up the disc then ejects it. Thanks
Re: Avengers Endgame
Post by Woodstock » Fri Oct 25, 2019 12:32 pm
If the drive is ejecting the disk, it is saying it can't read it. Did you, by chance, insert the UHD disk?
ncarusojr
Post by ncarusojr » Fri Oct 25, 2019 7:24 pm
No it’s definitely a blu ray. I don’t own a uhd player and it play fine in my regular blu ray player.
ncarusojr
Post by ncarusojr » Fri Oct 25, 2019 11:50 pm
this is what I'm getting.
Debug log started at Fri Oct 25 23:46:51 2019 , written by MakeMKV v1.14.5 darwin(x64-release)
001005:0000 MakeMKV v1.14.5 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/home/MakeMKV_log.txt
002010:0000 Optical drive "BD-ROM HL-DT-ST BDDVDRW CP40NG10 1.00d" opened in OS access mode.
No SDF v063: HL-DT-ST_BDDVDRW_CP40NG10_1.00_20111010162300_KVGBADG5059
SDF id v063: HL-DT-ST_BDDVDRW_CP40NG10_1.00_20111010162300_KVGBADG5059
Any ideas
Grauhaar
Post by Grauhaar » Sat Oct 26, 2019 8:55 am
Is the disc also ejected if MakeMKV is not running?
Never seen that MakeMKV ejects a disc. I think the disc could not be identified by the OS and MakeMKV never accesses the disc.
Good Luck :)
ncarusojr
Post by ncarusojr » Sat Oct 26, 2019 11:32 am
That is correct. It’s being ejected if MakeMKV is running or not running. It doesn’t matter. Disc spins up a couple of times then click it’s ejected. I thought it was a bad disc but it plays fine on my player. I thought maybe my Drive was bad but I tried a couple of blu rays in that and they were all fine. It’s super weird.
Post by Woodstock » Sat Oct 26, 2019 1:46 pm
Well, that means the drive is what is rejecting the disk; perhaps it is unable to read the "clock signals" on the disk.
It's been a LONG time since I saw this behavior, back when I first tried to use my "BDXL-compatible" drive to read a UHD (hence my suggestion).
If you cycle the power on the drive, which will force the operating system to re-initialize it, does it continue to happen with this disk?
ncarusojr
Post by ncarusojr » Mon Oct 28, 2019 3:30 pm
It must have been the disc. I got another one and it’s fine. Just weird it played fine in my Blu Ray Player. Thanks everyone for all the help.
cabwiz
Post by cabwiz » Sun Jan 05, 2020 7:12 pm
Hi all,
Looking for help with this error while trying to rip Endgame:
Saving 1 titles into directory F:/Video/MARVEL'S AVENGERS- ENDGAME
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00055.m2ts' at offset '29279907840'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '29279907840'
Failed to save title 0 to file F:/Video/MARVEL'S AVENGERS- ENDGAME/MARVEL'S AVENGERS- ENDGAME_t00.mkv
0 titles saved, 1 failed
