I bought American Gangster today and I don't seem to be able to back it up. I have attached the AACS dump file if anyone can help please?
MakeMKV v1.14.5 win(x64-release) started
Using LibreDrive mode (v05 id=4FBA32AEC678)
Saved AACS dump file as C:/Program Files (x86)/MakeMKV/MKB20_v72_American_Gangster_1B40.tgz
Thanks.
video can't be decrypted - American Gangster
- MKB20_v72_American_Gangster_1B40.tgz
- (3.29 MiB) Downloaded 590 times
Regards
Dave
Dave
Re: video can't be decrypted - American Gangster
1. UHD discs are discussed here:
https://www.makemkv.com/forum/viewforum.php?f=12
Since why that subforum is explicily called UHD discs.
2. Posting the dump in the forum is of no help to you or anyone else. They have to be submitted to Mike for processing. No one but him can do anything with that file. How? Forum search function works. Use it. This process has been addressed/discussed hundreds of times already.
https://www.makemkv.com/forum/search.ph ... is+unknown
3. Lastly, check to make sure your PC is downloading the SDF file. Some members were having problems receiving updates from MakeMKV that are needed for UHD disc decryption as discussed here:
https://www.makemkv.com/forum/viewtopic.php?f=1&t=17848
