Problematic HD-DVDs
cozzmo
Re: Problematic HD-DVDs
#16 Post by cozzmo » Sat Sep 25, 2010 2:45 am
1) The Mummy Returns
2) Universal
3) VC-1
4) DDplus
5) Audio selected for inclusion was English, audio in MKV, Japanese :lol: I did this 2 times and the result was the same. I will try it again with all lanugages selected to see which ones turns out to be the English track.
6) Debug log contains no errors.
MakeMKV v1.6.0 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\*****/MakeMKV_log.txt
DEBUG: Code 0 at L-Mzv($j15?CI&O-y:121262164
Saving 1 titles into directory E://MUMMYRETURNSG41
1 titles saved
EDIT: OK ripped all tracks to an MKV
Labelled / Actual
1 French / English
2 Italiano / French
3 Deutsch / Italiano
4 Espanol / Deutsch
5 Japenese / Espanol
6 English / Japanese
madpoet
#17 Post by madpoet » Sat Sep 25, 2010 6:04 pm
1) Eyes Wide Shut
2) WB
3) VC-1
4) TrueHD and DD+
5) I hear the drive just churning and then it fails. Plays back fine in Powerdvd.
6) Not sure how to get it
setarip_old
#18 Post by setarip_old » Sat Sep 25, 2010 9:50 pm
@madpoet
Click on the "Preferences" icon (wrench) and put a checkmark next to "Log debug messages" and then exit and restart MakeMKV. If you now look in that same area, you'll see the location where your debug logs will be saved...
daredavel
#19 Post by daredavel » Tue Sep 28, 2010 5:10 am
First of all, i'd like to say makemkv is an awesome program! It's worked very well with everything so far until I tried a couple discs today (for fear of my hd-dvd drive breaking down).
I have a feeling it might have something to do with mpeg4 codec. I deselected all the mpeg4 tracks, and tried the vc-1 titles (dreamworks logo) and it was fine. The same thing happened when I tried Stardust, I selected the mpeg2 titles on the same disc and those titles worked fine. I'm using all original commercial discs, not rips/iso's.
1) Transformers
2) Paramount
3) Mpeg4
4) DDPlus 3/2+1
5) fails to save
6) Debug log
Saving 1 titles into directory K:/Movies/Transformers
DEBUG: Code 7 at TF(=\P&/_wGL>m6PIvFM:121264050
DEBUG: Code 0 at A/g'goY"dcOFcea@e@@Go:29397449
DEBUG: Code 0 at 8a;4xqx++vbtp=E-85I:121263751
Failed to save title 0 to file K:/Movies/Transformers/t00_Main_Menu.mkv
0 titles saved, 1 failed
cozzmo
#20 Post by cozzmo » Wed Sep 29, 2010 6:58 am
Same.
Failed at 11436.6MB
FIXED / successfully ripped with 1.6.3
Debug Log:
Saving 1 titles into directory E://TRANSFORMERS_D1_NA
DEBUG: Code 0 at 'KpGdm~*:Y=-6rTtu7{:213133204
Failed to save title 2 to file E://TRANSFORMERS_D1_NA/t02_Main_Movie.mkv
daredavel wrote:First of all, i'd like to say makemkv is an awesome program! It's worked very well with everything so far until I tried a couple discs today (for fear of my hd-dvd drive breaking down).
1) Transformers
2) Paramount
3) Mpeg4
4) DDPlus 3/2+1
5) fails to save
6) Debug log
cozzmo
#21 Post by cozzmo » Wed Sep 29, 2010 8:42 am
1) The Fast and the Furious
2) Universal
3) Unknown
4) DDplus
5) Fails to open the disc
6) Debug Log:
DEBUG: Code 89 at ehvMHF8Z~[4 .:213131824
DEBUG: Code 0 at ehvMHF8Z~[4 .:121261773
JishanF
#22 Post by JishanF » Fri Oct 01, 2010 12:16 am
1)Superman Returns
2)Warner Bros
3)VC-1
4)DDplus, TrueHD 5.1
5)Fails about 3/4 of the way through
6)
001003:0020 DEBUG: Code 0 at STZ'[#r1Q>d8(*8LL1j:121263958
001003:0020 DEBUG: Code 0 at Qw6tPdIGeB]:P.:1gJR;:29394298
001003:0020 DEBUG: Code 0 at 6B/VDTmY-h Vtg3=Czx:29393838
001003:0020 DEBUG: Code 0 at Qw6tPdIGeB]:P.:1gJR;:29394183
001003:0020 DEBUG: Code 4921742 at Qw6tPdIGeB]:P.:1gJR;:29393309
005003:0000 Failed to save title 0 to file L:/Blu-Ray Rips/t00_Feature_Presentation.mkv
005004:0080 0 titles saved, 1 failed
Also wanted to say that Batman Begins does work. I was able to back it up without issue.
cozzmo
#23 Post by cozzmo » Fri Oct 01, 2010 4:53 am
Can you check that again because mine copied just fine. You might have a bad disk?
JishanF wrote:1)Superman Returns
2)Warner Bros
3)VC-1
6)
Krobar
#24 Post by Krobar » Fri Oct 01, 2010 6:59 am
mpataky wrote:I've tried 2 HD-DVD's so far, Forbidden Planet and Cat People, both had no problems making the "MKV" but there is no audio ... however the video is fine ... no errors in the debug log ... help!!
Can confirm Audio is fine for me with Cat People rip.
madpoet
#25 Post by madpoet » Fri Oct 01, 2010 9:09 pm
1) Pan's Labyrinth
2) Newline
3) Not sure
4) DTS HDMA
5) Fails to open disk
6)
DEBUG: Code 0 at {'iOdX&Wstj<iFtYn:121262164
DEBUG: Code 0 at :)_9A/U}b6J3s:29393654
madpoet
#26 Post by madpoet » Fri Oct 01, 2010 9:31 pm
cozzmo wrote:1) Top Gun
2) Paramount
3) mpeg4
4) TrueHD 5.1, DTS 3/2+1
5) Stops at 8961.8mb each time. Disc has been cleaned & checked.
6) Debug log below:
Debug logging enabled, log will be saved as C:\Users\****/MakeMKV_log.txt
Evaluation version, 28 day(s) out of 30 remaining
DEBUG: Code 989 at A/g'goY"dcOFcea@e@@Go:213132974
Saving 1 titles into directory D://TOPGUN
Failed to save title 0 to file D://TOPGUN/t00_Main_Movie.mkv
Also had this one fail... same error
madpoet
#27 Post by madpoet » Fri Oct 01, 2010 9:40 pm
Reposted with logs:
1) Eyes Wide Shut
2) WB
3) VC-1
4) TrueHD and DD+
6)
Saving 1 titles into directory C:/Video/EYES_WIDE_SHUT_SE_HD_DVD
DEBUG: Code 100927745 at ({KcoB=x8&.$yvq+@):29395839
DEBUG: Code 100927745 at ({KcoB=x8&.$yvq+@):121261727
Error 'Scsi error - HARDWARE ERROR:TRACKING SERVO FAILURE' occurred while reading '/HVDVD_TS/feature_01.EVO' at offset '14661464064'
DEBUG: Code 0 at UJ2s1hNR*~VIfAp-;cE:121263958
DEBUG: Code 7158918 at 8-%q^PxUnKZZ&rfxC>;:29397035
DEBUG: Code 0 at mbekjYvz,FE4*_>|AuF:213132790
Failed to save title 0 to file C:/Video/EYES_WIDE_SHUT_SE_HD_DVD/t00_Feature_Presentation.mkv
setarip_old
#28 Post by setarip_old » Fri Oct 01, 2010 9:46 pm
Hi!
This is usually indicative of a failing drive or (if you're lucky) a dirty lens...
madpoet
#29 Post by madpoet » Fri Oct 01, 2010 10:03 pm
Yeah but I can watch it just fine in PowerDVD on the same drive.
cozzmo
#30 Post by cozzmo » Fri Oct 01, 2010 10:07 pm
I got one of those scsi errors with one of the Bourne movies, i just let it go for a while and it got past it and finished the movie. Surface of the disc was spotless and i've had no other issues like that with any other disk. It was a combo HD/DVD disc which i thought maybe they were more fragile or something.
