It's a Wonderful Life on 4K UHD Blu-ray
Someguy1234
#1 Post by Someguy1234 » Mon Oct 21, 2019 3:12 pm
I'm getting this error saying that the volume key is unknown for IT'S A WONDERFUL LIFE on 4K UHD Blu-ray. I've submitted the dump file via e-mail. Has anyone else yet?
Log:
MakeMKV v1.14.5 win(x64-release) started
Using LibreDrive mode (v05 id=DA23CAE0BD2F)
Downloading latest HK to D:/MakeMKV ...
Saved AACS dump file as D:/MakeMKV/MKB20_v72_It's_A_Wonderful_Life_03FE.tgz
gamereviewgod
Re: It's a Wonderful Life on 4K UHD Blu-ray
#2 Post by gamereviewgod » Mon Oct 21, 2019 7:40 pm
You got farther than I did. I'm getting a fatal error with this and Wizard of Oz.
BlueMac77
#3 Post by BlueMac77 » Mon Oct 21, 2019 8:38 pm
Maybe wait for a couple of days and the new hash key will be available by that time.
Someguy1234
#4 Post by Someguy1234 » Tue Oct 22, 2019 2:36 am
Wow. I figured it would have the same issue. I'm turning out right about things today. I'd say this will be able to rip in a day or two like the person below said.
rbphelan
#5 Post by rbphelan » Wed Oct 30, 2019 3:43 am
I received my copy today and was able to decode it.
buzzshipman
#6 Post by buzzshipman » Sun Dec 24, 2023 2:43 pm
I know this an old post but I just got the 4K and am unable to decode it. Anyone know of a fix
#7 Post by d00zah » Sun Dec 24, 2023 3:34 pm
Per UHD FAQ:
MakeMKV says that "the volume key is unknown for this disc"?
MakeMKV produces an AACS .tgz dump file whenever you try to open a disc for which the key is unknown, and will report that the dump has been created. Email the dump file to svq@makemkv.com.
I submitted a dump, how long does it take?
Once submitted, the turnaround can be pretty fast, between 12 to 48 hours. However, it can also sometimes take several days or longer.
When you submit a dump, ensure that:
- You are using the latest version of MakeMKV.
- You are using a LibreDrive-enabled drive (be it "friendly" or "official", but it must be LibreDrive enabled).
- You have "Enable Internet access" enabled in Preferences (in the General tab), so that MakeMKV will check for updated keys when you try to open the disc again.
- You are opening the original disc (not a backup, not ISO).
- You are opening the disc using a real disc drive natively (no elby clonedrive, no vmware, no dvdfab or discsoft virtual, etc).
