franz
Post by franz » Fri Oct 18, 2019 10:13 pm
Hi thanks for reply, now when I try to flash the firmware for asus bc-12d2ht I get the error # 5
Post by Billycar11 » Fri Oct 18, 2019 10:59 pm
franz wrote: Fri Oct 18, 2019 10:13 pm Hi thanks for reply, now when I try to flash the firmware for asus bc-12d2ht I get the error # 5
does the drive still work like read disks and stuff?
2 people here report that flashing it to ASUS-BW-16D1H-U-A204-WM01001-211901041044.bin works i have not personally tested that though
https://www.makemkv.com/forum/viewtopic ... 19&t=20595
franz
Post by franz » Sat Oct 19, 2019 6:53 am
Billycar11 wrote: Fri Oct 18, 2019 10:59 pm
Thanks for reply. No, I tested the unit for watching and backing up the movie and it's unusable because of too many reading errors. Furthermore it is no longer able to burn any disc.
Do you have any idea what I can try to do to flash the correct firmware (DE bc-12d2ht 3.00)?
franz
Post by franz » Sat Oct 19, 2019 7:25 am
maybe if someone supplies the 3.10 firmware for bc-12d2ht I can try to use it as an intermediate step. or maybe I'm wrong?
franz
Post by franz » Sat Oct 19, 2019 8:05 am
I read the topic. I flashed the ASUS-BW-16D1H-U-A204-WM01001-211901041044.bin successfully, but afterwards I can't flash any firmware for bc-12d2ht anyway. although as I read in the topic I could flash the DE_LG_WH16NS60_1.00.bin but even from here I can't flash the one for bc-12d2ht. now I have reflashed the 3.10mk.
Post by MartyMcNuts » Sat Oct 19, 2019 10:48 pm
franz wrote: Sat Oct 19, 2019 8:05 am
It makes me wonder if my latest flasher update caused this issue. It can be difficult as I don't have one of each different drive to test it with!!
@franz, can you please try using the old flasher. I have attached it for you. It works exactly the same way.
(Attachment removed as it didn’t help)
Please let us know if this works for you.
franz
Post by franz » Sun Oct 20, 2019 9:07 am
MartyMcNuts wrote: Sat Oct 19, 2019 10:48 pm
ASUS_ODD_FW_Changer_(Modified)-old.zip
Thanks for the reply. Unfortunately it didn't work. Always error # 5, like the most recent version
Post by MartyMcNuts » Sun Oct 20, 2019 9:34 am
franz wrote: Sun Oct 20, 2019 9:07 am
Ok. At least I now know it’s not the flasher. Doesn’t help you though... I’ll have a think about it and see if I can come up with something else for you.
franz
Post by franz » Sun Oct 20, 2019 9:40 am
I share the details of the burner:
franz
Post by franz » Sun Oct 20, 2019 10:02 am
MartyMcNuts wrote: Sun Oct 20, 2019 9:34 am
thanks
f....
Post by f.... » Sun Oct 20, 2019 11:40 pm
Hi, I just bought an LG BP60NB10, manufactured in July 2019 with firmware version 1.01. I'm trying to downgrade the firmware, but I'm running into errors.
I downloaded the "(Modified) ASUS ODD FW Changer + UHD Friendly Firmwares (24.08.2019)" flasher, and attempted to flash it with the "HL-DT-ST-BD-RE_BP60NB10-1.00-NM00200-211711211720.bin" file located in the "MK\HL-DT-ST\BP60NB10" folder. When I do, I get "error #4". I don't know what this means, but I'm assuming I must have made a mistake somewhere.
Am I using the wrong tool / firmware version? Any help would be greatly appreciated, since I'm pretty new to this.
Post by MartyMcNuts » Mon Oct 21, 2019 1:10 am
@f.... @wellandman
I'd say that 1.01 is fairly new and has probably disabled downgrading.
There still is not a 1.01 version in the MK pack either. Maybe one of you guys can contact mike admin and see if he can possibly extract it from your drive.
franz
Post by franz » Mon Oct 21, 2019 8:53 pm
franz wrote: Sun Oct 20, 2019 10:02 am
thanks
if there is any other information that may be useful to help you understand what the problem is just ask me
cheers
Jake308
Post by Jake308 » Tue Oct 22, 2019 10:07 am
Hi Guys,
I have the choice of drives to purchase. ASUS bw-16d1ht or LG bh16ns55. Is there any reason to pick one over the other in regards to UHD friendly. The LG is considerably cheaper. Cheers.
franz
Post by franz » Tue Oct 22, 2019 10:53 pm
StoneMkv wrote: Mon May 27, 2019 10:44 am
Billycar11 wrote: Fri May 24, 2019 7:16 pm
StoneMkv wrote: Fri May 24, 2019 1:47 pm can not find any tool to downgrade BC-12D2HT from 3.11 to 3.10 at this location. Might be removed.
Any other resource available?
ASUS_ODD_FW_Changer_(Modified).exe is always throwing Error #4
You just flash the bw16d1ht 3.10 and if you don't want that firmware then flash your firmware of choice it the only way to drown grade for now if you have 3.10 or higher on Asus drives
I managed to flash BC-12D2HT from 3.1 to BW-16D1HT 3.10 now. Seems to support Lib Drive mode now. THANK YOU.
If I try to flash another FW is now throwing Error #5
@StoneMkv I seem to be in a similar situation to yours. how did you solve?
