#646 Post by SamuriHL » Wed Oct 16, 2019 4:30 pm
st4evr wrote:
Wed Oct 16, 2019 4:14 pm
SamuriHL wrote:
Wed Oct 16, 2019 3:37 pm
Hopefully this clears up the issue of why it's not happening any time soon once and for all.
Give it another few days/weeks, but we can dream can't we? :wink: :lol:
Rebellions are built on hope. :D
bronan
#647 Post by bronan » Fri Oct 18, 2019 3:14 am
Has anyone had any luck with the Shining? The first MP4 created with mp4muxer with the 2 video streams works great on my Oppo, but after sending it through mp4box, either with or without an audio stream, it immediately locks up on the Warner bros shield. I'm using the one from the SDK pack, and also tried compiling the latest from the filters branch with same result.
I also noticed a couple lines of output when running mp4box I wasn't sure was normal or not:
[iso file] Unknown box type hvcC in parent dvhe
[iso file] dvcC reserved bytes are not zero
daddy
#648 Post by daddy » Sat Oct 19, 2019 9:37 am
No problem with the Shining. The file play normally.
Général
Nom complet                              : Y:\4k\Shining [ac3][4k][DV].mp4
Profil du format                         : Base Media / Version 2
Identifiant du codec                     : mp42 (mp42/dby1/isom)
Taille du fichier                        : 75,3 Gio
Durée                                    : 2 h 23 min
Débit global moyen                       : 75,0 Mb/s
Date d'encodage                          : UTC 2019-09-25 05:55:28
Date de marquage                         : UTC 2019-09-25 05:55:28
Vidéo #1
Profil du format                         : Main 10@L5.1@High
HDR_Format/String                        : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Identifiant du codec                     : hev1
Identifiant du codec/Info                : High Efficiency Video Coding
Durée                                    : 2 h 23 min
Débit                                    : 74,3 Mb/s
Largeur                                  : 3 840 pixels
Hauteur                                  : 2 160 pixels
Format à l'écran                         : 16/9
Type d'images/s                          : Constant
Images par seconde                       : 23,976 (24000/1001) Im/s
Espace de couleurs                       : YUV
Sous-échantillonnage de la chrominance   : 4:2:0 (Type 2)
Profondeur des couleurs                  : 10 bits
Bits/(Pixel*Image)                       : 0.373
Taille du flux                           : 74,6 Gio (99%)
Default                                  : Non
Gamme de couleurs                        : Limited
Coordonnées de chromaticité              : BT.2020
Caractéristiques du transfert            : PQ
Coefficients de la matrice               : BT.2020 non-constant
MasteringDisplay_ColorPrimaries          : Display P3
MasteringDisplay_Luminance               : min: 0.0050 cd/m2, max: 4000 cd/m2
MaxCLL                                   : 1633 cd/m2
MaxFALL                                  : 114 cd/m2
Codec configuration box                  : hvcC
Vidéo #2
HDR_Format/String                        : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
Identifiant du codec                     : dvhe
Identifiant du codec/Info                : High Efficiency Video Coding with Dolby Vision
Durée                                    : 2 h 23 min
Débit                                    : 64,2 kb/s
Largeur                                  : 1 920 pixels
Hauteur                                  : 1 080 pixels
Bits/(Pixel*Image)                       : 0.001
Taille du flux                           : 66,1 Mio (0%)
Default                                  : Non
Audio
Nom commercial                           : Dolby Digital
Identifiant du codec                     : ac-3
Durée                                    : 2 h 23 min
Type de débit                            : Constant
Débit                                    : 640 kb/s
Canaux                                   : 6 canaux
ChannelLayout                            : L R C LFE Ls Rs
Echantillonnage                          : 48,0 kHz
Images par seconde                       : 31,250 Im/s (1536 SPF)
Mode de compression                      : Avec perte
Taille du flux                           : 658 Mio (1%)
Langue                                   : Français
ServiceKind/String                       : Complete Main
Default                                  : Non
SoNNiBoi
#649 Post by SoNNiBoi » Sat Oct 19, 2019 6:39 pm
Smanet wrote:
Wed Oct 09, 2019 10:19 am
I have a 5.1.4 speaker setup and I'm finding myself conflicted on the following:
1) Watch the backup with DV + LPCM 7.1 (converted from TrueHD)
2) Watch the backup with DV + DTS-MA (I believe this should work with MP4 but I haven't tested it. Or is it worth more to convert DTS-MA to LPCM instead of TrueHD, again if possible?)
3) Watch the backup without DV but with Atmos (is there any appreciable difference with HDR10? I have a LG C8)
Hi Smanet, i also played last time a bit with the tools ffmpeg, mp4muxer and mp4box. In the end I muxed a movie with DV and several (original) DTS-HD tracks in it and it works perfectly fine with my C8 (directly played). Look here:
Vollständiger Name                       : D:\Video\UHD\Apocalypse.Now.1979.Redux.German.DTS-HD.MA.DL.2160p.UHD.BluRay.HDR.Dolby.Vision.HEVC.Remux-SoNNiBoi.mp4
Format-Profil                            : Base Media / Version 2
Codec-ID                                 : mp42 (isom/mp42/dby1)
Dateigröße                               : 69,7 GiB
Dauer                                    : 3 h 16 min
Modus der Gesamtbitrate                  : variabel
Gesamte Bitrate                          : 50,9 Mb/s
Kodierungs-Datum                         : UTC 2019-10-18 07:48:07
Tagging-Datum                            : UTC 2019-10-18 07:48:07
Video #1
Format-Profil                            : Main 10@L5.1@High
HDR_Format/String                        : SMPTE ST 2086, HDR10 compatible
Codec-ID                                 : hev1
Codec-ID/Info                            : High Efficiency Video Coding
Dauer                                    : 3 h 16 min
Source_Duration/String                   : 46 min 55s
Bitrate                                  : 38,2 Mb/s
maximale Bitrate                         : 79,1 Mb/s
Breite                                   : 3 840 Pixel
Höhe                                     : 2 160 Pixel
Bildseitenverhältnis                     : 16:9
Modus der Bildwiederholungsrate          : konstant
Bildwiederholungsrate                    : 23,976 (24000/1001) FPS
ColorSpace                               : YUV
ChromaSubsampling/String                 : 4:2:0 (Type 2)
BitDepth/String                          : 10 bits
Bits/(Pixel*Frame)                       : 0.192
Stream-Größe                             : 52,4 GiB (75%)
Source_StreamSize/String                 : 52,4 GiB (75%)
Default                                  : Nein
Kodierungs-Datum                         : UTC 2019-10-14 10:47:35
Tagging-Datum                            : UTC 2019-10-18 08:33:34
colour_range                             : Limited
colour_primaries                         : BT.2020
transfer_characteristics                 : PQ
matrix_coefficients                      : BT.2020 non-constant
MasteringDisplay_Luminance               : min: 0.0010 cd/m2, max: 1000 cd/m2
MaxCLL                                   : 1000 cd/m2
MaxFALL                                  : 363 cd/m2
mdhd_Duration                            : 11763753
Video #2
Codec-ID                                 : dvhe
Codec-ID/Info                            : High Efficiency Video Coding with Dolby Vision
Dauer                                    : 3 h 16 min
Bitrate                                  : 5 600 kb/s
maximale Bitrate                         : 16,2 Mb/s
Breite                                   : 1 920 Pixel
Höhe                                     : 1 080 Pixel
ColorSpace                               : YUV
Bits/(Pixel*Frame)                       : 0.113
Stream-Größe                             : 7,67 GiB (11%)
Source_StreamSize/String                 : 7,67 GiB (11%)
Default                                  : Nein
MaxCLL                                   : 1000 cd/m2
MaxFALL                                  : 363 cd/m2
Audio #1
Format                                   : DTS XLL
Format_Commercial_IfAny                  : DTS-HD Master Audio
Codec-ID                                 : mp4a-A9
Dauer                                    : 3 h 16 min
Bitraten-Modus                           : variabel
Bitrate                                  : 2 009 kb/s
maximale Bitrate                         : 3 402 kb/s
Kanäle                                   : 6 Kanäle
ChannelLayout                            : C L R Ls Rs LFE
Samplingrate                             : 48,0 kHz
Bildwiederholungsrate                    : 93,750 FPS (512 SPF)
BitDepth/String                          : 16 bits
Stream-Größe                             : 2,75 GiB (4%)
Sprache                                  : Deutsch
Default                                  : Ja
AlternateGroup/String                    : 1
Audio #2
Format                                   : DTS XLL
Codec-ID                                 : mp4a-A9
Dauer                                    : 3 h 16 min
Bitrate                                  : 4 582 kb/s
maximale Bitrate                         : 6 161 kb/s
Kanäle                                   : 8 Kanäle
ChannelLayout                            : C L R LFE Lb Rb Lss Rss
BitDepth/String                          : 24 bits
Stream-Größe                             : 6,27 GiB (9%)
Sprache                                  : Englisch
Default                                  : Nein
Audio #3
Codec-ID                                 : ac-3
Dauer                                    : 3 h 16 min
Bitraten-Modus                           : konstant
Bitrate                                  : 448 kb/s
maximale Bitrate                         : 473 kb/s
Stream-Größe                             : 628 MiB (1%)
Sprache                                  : Englisch
Default                                  : Nein
More details on request ...
SoNNiBoi
#650 Post by SoNNiBoi » Sun Oct 20, 2019 10:11 am
Hi bronan, I noticed the lines too and igrored them. But the mux with mp4box works still as described above...
bronan
#651 Post by bronan » Sun Oct 20, 2019 2:56 pm
Général
Durée                                    : 2 h 23 min
Vidéo #1
Durée                                    : 2 h 23 min
Débit                                    : 74,3 Mb/s
Default                                  : Non
MaxCLL                                   : 1633 cd/m2
MaxFALL                                  : 114 cd/m2
Vidéo #2
Durée                                    : 2 h 23 min
Débit                                    : 64,2 kb/s
Default                                  : Non
Audio
Durée                                    : 2 h 23 min
Débit                                    : 640 kb/s
Canaux                                   : 6 canaux
Langue                                   : Français
Default                                  : Non
I noticed you are using AC3 audio, which I am able to mux without problem with mp4muxer. Did you use mp4box at all though for lossless audio?
Edit: It seems its just a problem with the Oppo 203 player. I tried both through network share and USB and get the immediate lockup, but playing directly on my LG OLED via USB and it works fine. Hmm..
superfans124
#652 Post by superfans124 » Sun Oct 20, 2019 6:24 pm
Général
Durée                                    : 2 h 23 min
Vidéo #1
Durée                                    : 2 h 23 min
Débit                                    : 74,3 Mb/s
Default                                  : Non
MaxCLL                                   : 1633 cd/m2
MaxFALL                                  : 114 cd/m2
Vidéo #2
Durée                                    : 2 h 23 min
Débit                                    : 64,2 kb/s
Default                                  : Non
Audio
Durée                                    : 2 h 23 min
Débit                                    : 640 kb/s
Canaux                                   : 6 canaux
Langue                                   : Français
Default                                  : Non
Can't the 203 play directly from the BDMV folder thus avoid having the trouble of remuxing?
Smanet
#653 Post by Smanet » Sun Oct 20, 2019 6:29 pm
Dauer                                    : 3 h 16 min
Video #1
Codec-ID                                 : hev1
Dauer                                    : 3 h 16 min
Bitrate                                  : 38,2 Mb/s
Höhe                                     : 2 160 Pixel
ColorSpace                               : YUV
Default                                  : Nein
MaxCLL                                   : 1000 cd/m2
MaxFALL                                  : 363 cd/m2
Video #2
Codec-ID                                 : dvhe
Dauer                                    : 3 h 16 min
Höhe                                     : 1 080 Pixel
ColorSpace                               : YUV
Default                                  : Nein
MaxCLL                                   : 1000 cd/m2
MaxFALL                                  : 363 cd/m2
Audio #1
Format                                   : DTS XLL
Codec-ID                                 : mp4a-A9
Dauer                                    : 3 h 16 min
Kanäle                                   : 6 Kanäle
Sprache                                  : Deutsch
Default                                  : Ja
Audio #2
Format                                   : DTS XLL
Codec-ID                                 : mp4a-A9
Dauer                                    : 3 h 16 min
Kanäle                                   : 8 Kanäle
Sprache                                  : Englisch
Default                                  : Nein
Audio #3
Codec-ID                                 : ac-3
Dauer                                    : 3 h 16 min
Bitrate                                  : 448 kb/s
Sprache                                  : Englisch
Default                                  : Nein
Hi SoNNiBoi, I didn't know that the TV could play DV using the two separated video tracks, however the audio will not be transferred to the a/v receiver in this scenario as the TV doesn't have eARC support. Am I correct about this?
bronan
#654 Post by bronan » Sun Oct 20, 2019 7:01 pm
Général
Durée                                    : 2 h 23 min
Vidéo #1
Durée                                    : 2 h 23 min
Débit                                    : 74,3 Mb/s
Default                                  : Non
MaxCLL                                   : 1633 cd/m2
MaxFALL                                  : 114 cd/m2
Vidéo #2
Durée                                    : 2 h 23 min
Débit                                    : 64,2 kb/s
Default                                  : Non
Audio
Durée                                    : 2 h 23 min
Débit                                    : 640 kb/s
Canaux                                   : 6 canaux
Langue                                   : Français
Default                                  : Non
Yes, but I'm adding the original theatrical mono (Laserdisc PCM) to it so I have to remux regardless.
#655 Post by MartyMcNuts » Mon Oct 21, 2019 3:13 am
Slightly off topic and not sure if anyone cares but Kogan are now having a "Pre-Sale" on new Andriod TV's with Dolby Vision. The Aussie prices are:
  • Kogan 50" Smart HDR 4K LED Android TV = $449.99
  • Kogan 55" Smart HDR 4K LED Android TV = $499.99
  • Kogan 65" Smart HDR 4K LED Android TV = $799.99
Cheers!
superfans124
#656 Post by superfans124 » Mon Oct 21, 2019 2:01 pm
ok, let's see. was the mono pcm demuxed with ffmpeg? in my limited experience, I found mp4box works better with media streams demuxed with ffmpeg, even better if all demuxed from the same source. I seem to have experienced similar end result when the audio track was not "marked" by ffmpeg, mp4box would report something "unusual" and the mp4 did not play.
alternatively, but this is only my brainstorming without first hand experience, would it be possible to mux the mono pcm into the main movie m2ts file with tsMuxer?
SoNNiBoi
#657 Post by SoNNiBoi » Mon Oct 21, 2019 2:52 pm
@Smanet unfortunately, you are right. I hope there will be a firmware update very soon to enjoy HD-Sound...
bronan
#658 Post by bronan » Mon Oct 21, 2019 6:03 pm
There is no demuxing for laserdiscs since there is no real file structure, you have to capture the stream in real time. I was using tsmuxer before to export the video channels, so I'm trying out ffmpeg now to see if it makes any difference.
I thought about trying to make a new .m2ts with tsmuxer but unfortunately I'd have to resample the audio to 48kHz for it to accept it (LD is natively 44.1kHz). I did notice though that tsmuxer is open source now (yay!) so I might try to see if I can get around that restriction :)
Edit: It seems the point is moot since m2ts created by tsmuxer won't trigger Dolby Vision.
superfans124
#659 Post by superfans124 » Tue Oct 22, 2019 3:14 am
yikes, sorry, I wish I knew anything at all about the particular format to be of any help.
bronan
#660 Post by bronan » Tue Oct 22, 2019 4:37 am
It's OK, its working fine for me streaming to the TV's Video app via DLNA so I'm happy enough with it (the TV outputs to amp so sound is fine). Thanks for the help anyways!
I am working on a Windows GUI app btw to simplify the remuxing process, will share when its ready
