SoNNiBoi
Post by SoNNiBoi »
Smanet wrote: Wed Oct 09, 2019 10:19 am
I have a 5.1.4 speaker setup and I'm finding myself conflicted on the following:
1) Watch the backup with DV + LPCM 7.1 (converted from TrueHD)
2) Watch the backup with DV + DTS-MA (I believe this should work with MP4 but I haven't tested it. Or is it worth more to convert DTS-MA to LPCM instead of TrueHD, again if possible?)
3) Watch the backup without DV but with Atmos (is there any appreciable difference with HDR10? I have a LG C8)
Hi Smanet, i also played last time a bit with the tools ffmpeg, mp4muxer and mp4box. In the end I muxed a movie with DV and several (original) DTS-HD tracks in it and it works perfectly fine with my C8 (directly played). Look here:
Vollständiger Name                       : D:\Video\UHD\Apocalypse.Now.1979.Redux.German.DTS-HD.MA.DL.2160p.UHD.BluRay.HDR.Dolby.Vision.HEVC.Remux-SoNNiBoi.mp4
Format-Profil                            : Base Media / Version 2
Codec-ID                                 : mp42 (isom/mp42/dby1)
Dateigröße                               : 69,7 GiB
Dauer                                    : 3 h 16 min
Modus der Gesamtbitrate                  : variabel
Gesamte Bitrate                          : 50,9 Mb/s
Kodierungs-Datum                         : UTC 2019-10-18 07:48:07
Tagging-Datum                            : UTC 2019-10-18 07:48:07
Video #1
Format-Profil                            : Main 10@L5.1@High
HDR_Format/String                        : SMPTE ST 2086, HDR10 compatible
Codec-ID                                 : hev1
Codec-ID/Info                            : High Efficiency Video Coding
Dauer                                    : 3 h 16 min
Source_Duration/String                   : 46 min 55s
Bitrate                                  : 38,2 Mb/s
maximale Bitrate                         : 79,1 Mb/s
Breite                                   : 3 840 Pixel
Höhe                                     : 2 160 Pixel
Bildseitenverhältnis                     : 16:9
Modus der Bildwiederholungsrate          : konstant
Bildwiederholungsrate                    : 23,976 (24000/1001) FPS
ColorSpace                               : YUV
ChromaSubsampling/String                 : 4:2:0 (Type 2)
BitDepth/String                          : 10 bits
Bits/(Pixel*Frame)                       : 0.192
Stream-Größe                             : 52,4 GiB (75%)
Source_StreamSize/String                 : 52,4 GiB (75%)
Default                                  : Nein
Kodierungs-Datum                         : UTC 2019-10-14 10:47:35
Tagging-Datum                            : UTC 2019-10-18 08:33:34
colour_range                             : Limited
colour_primaries                         : BT.2020
transfer_characteristics                 : PQ
matrix_coefficients                      : BT.2020 non-constant
MasteringDisplay_ColorPrimaries          : Display P3
MasteringDisplay_Luminance               : min: 0.0010 cd/m2, max: 1000 cd/m2
MaxCLL                                   : 1000 cd/m2
MaxFALL                                  : 363 cd/m2
mdhd_Duration                            : 11763753
Codec configuration box                  : hvcC
Video #2
HDR_Format/String                        : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec-ID                                 : dvhe
Codec-ID/Info                            : High Efficiency Video Coding with Dolby Vision
Dauer                                    : 3 h 16 min
Bitrate                                  : 5 600 kb/s
maximale Bitrate                         : 16,2 Mb/s
Breite                                   : 1 920 Pixel
Höhe                                     : 1 080 Pixel
ColorSpace                               : YUV
Bits/(Pixel*Frame)                       : 0.113
Stream-Größe                             : 7,67 GiB (11%)
Source_StreamSize/String                 : 7,67 GiB (11%)
Default                                  : Nein
MaxCLL                                   : 1000 cd/m2
MaxFALL                                  : 363 cd/m2
Audio #1
Format                                   : DTS XLL
Format_Commercial_IfAny                  : DTS-HD Master Audio
Codec-ID                                 : mp4a-A9
Dauer                                    : 3 h 16 min
Bitraten-Modus                           : variabel
Bitrate                                  : 2 009 kb/s
maximale Bitrate                         : 3 402 kb/s
Kanäle                                   : 6 Kanäle
ChannelLayout                            : C L R Ls Rs LFE
Samplingrate                             : 48,0 kHz
Bildwiederholungsrate                    : 93,750 FPS (512 SPF)
BitDepth/String                          : 16 bits
Stream-Größe                             : 2,75 GiB (4%)
Sprache                                  : Deutsch
Default                                  : Ja
AlternateGroup/String                    : 1
Audio #2
Format                                   : DTS XLL
Codec-ID                                 : mp4a-A9
Dauer                                    : 3 h 16 min
Bitrate                                  : 4 582 kb/s
maximale Bitrate                         : 6 161 kb/s
Kanäle                                   : 8 Kanäle
ChannelLayout                            : C L R LFE Lb Rb Lss Rss
BitDepth/String                          : 24 bits
Stream-Größe                             : 6,27 GiB (9%)
Sprache                                  : Englisch
Default                                  : Nein
Audio #3
Codec-ID                                 : ac-3
Dauer                                    : 3 h 16 min
Bitraten-Modus                           : konstant
Bitrate                                  : 448 kb/s
maximale Bitrate                         : 473 kb/s
Stream-Größe                             : 628 MiB (1%)
Sprache                                  : Englisch
Default                                  : Nein
More details on request ...
SoNNiBoi
Post by SoNNiBoi »
bronan wrote: Fri Oct 18, 2019 3:14 am Has anyone had any luck with the Shining? The first MP4 created with mp4muxer with the 2 video streams works great on my Oppo, but after sending it through mp4box, either with or without an audio stream, it immediately locks up on the Warner bros shield. I'm using the one from the SDK pack, and also tried compiling the latest from the filters branch with same result.
I also noticed a couple lines of output when running mp4box I wasn't sure was normal or not:
[iso file] Unknown box type hvcC in parent dvhe
[iso file] dvcC reserved bytes are not zero
Hi bronan, I noticed the lines too and igrored them. But the mux with mp4box works still as described above...
bronan
Post by bronan »
daddy wrote: Sat Oct 19, 2019 9:37 am No problem with the Shining. The file play normally.
Général
Nom complet                              : Y:\4k\Shining [ac3][4k][DV].mp4
Profil du format                         : Base Media / Version 2
Identifiant du codec                     : mp42 (mp42/dby1/isom)
Taille du fichier                        : 75,3 Gio
Durée                                    : 2 h 23 min
Débit global moyen                       : 75,0 Mb/s
Date d'encodage                          : UTC 2019-09-25 05:55:28
Date de marquage                         : UTC 2019-09-25 05:55:28
Vidéo #1
Profil du format                         : Main 10@L5.1@High
HDR_Format/String                        : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Identifiant du codec                     : hev1
Identifiant du codec/Info                : High Efficiency Video Coding
Durée                                    : 2 h 23 min
Débit                                    : 74,3 Mb/s
Largeur                                  : 3 840 pixels
Hauteur                                  : 2 160 pixels
Format à l'écran                         : 16/9
Type d'images/s                          : Constant
Images par seconde                       : 23,976 (24000/1001) Im/s
Espace de couleurs                       : YUV
Sous-échantillonnage de la chrominance   : 4:2:0 (Type 2)
Profondeur des couleurs                  : 10 bits
Bits/(Pixel*Image)                       : 0.373
Taille du flux                           : 74,6 Gio (99%)
Default                                  : Non
Gamme de couleurs                        : Limited
Coordonnées de chromaticité              : BT.2020
Caractéristiques du transfert            : PQ
Coefficients de la matrice               : BT.2020 non-constant
MasteringDisplay_Luminance               : min: 0.0050 cd/m2, max: 4000 cd/m2
MaxCLL                                   : 1633 cd/m2
MaxFALL                                  : 114 cd/m2
Vidéo #2
Identifiant du codec                     : dvhe
Identifiant du codec/Info                : High Efficiency Video Coding with Dolby Vision
Durée                                    : 2 h 23 min
Débit                                    : 64,2 kb/s
Largeur                                  : 1 920 pixels
Hauteur                                  : 1 080 pixels
Bits/(Pixel*Image)                       : 0.001
Taille du flux                           : 66,1 Mio (0%)
Default                                  : Non
Audio
Nom commercial                           : Dolby Digital
Identifiant du codec                     : ac-3
Durée                                    : 2 h 23 min
Type de débit                            : Constant
Débit                                    : 640 kb/s
Canaux                                   : 6 canaux
ChannelLayout                            : L R C LFE Ls Rs
Echantillonnage                          : 48,0 kHz
Images par seconde                       : 31,250 Im/s (1536 SPF)
Mode de compression                      : Avec perte
Taille du flux                           : 658 Mio (1%)
Langue                                   : Français
ServiceKind/String                       : Complete Main
Default                                  : Non
I noticed you are using AC3 audio, which I am able to mux without problem with mp4muxer. Did you use mp4box at all though for lossless audio?
Edit: It seems its just a problem with the Oppo 203 player. I tried both through network share and USB and get the immediate lockup, but playing directly on my LG OLED via USB and it works fine. Hmm..
superfans124
Post by superfans124 »
bronan wrote: Sun Oct 20, 2019 2:56 pm
Général
Durée                                    : 2 h 23 min
Vidéo #1
Durée                                    : 2 h 23 min
Débit                                    : 74,3 Mb/s
Default                                  : Non
MaxCLL                                   : 1633 cd/m2
MaxFALL                                  : 114 cd/m2
Vidéo #2
Durée                                    : 2 h 23 min
Débit                                    : 64,2 kb/s
Default                                  : Non
Audio
Durée                                    : 2 h 23 min
Débit                                    : 640 kb/s
Canaux                                   : 6 canaux
Langue                                   : Français
Default                                  : Non
Can't the 203 play directly from the BDMV folder thus avoid having the trouble of remuxing?
Smanet
Post by Smanet »
SoNNiBoi wrote: Sat Oct 19, 2019 6:39 pm Hi Smanet, i also played last time a bit with the tools ffmpeg, mp4muxer and mp4box. In the end I muxed a movie with DV and several (original) DTS-HD tracks in it and it works perfectly fine with my C8 (directly played). Look here:
Dauer                                    : 3 h 16 min
Video #1
Codec-ID                                 : hev1
Dauer                                    : 3 h 16 min
Bitrate                                  : 38,2 Mb/s
Höhe                                     : 2 160 Pixel
ColorSpace                               : YUV
Default                                  : Nein
MaxCLL                                   : 1000 cd/m2
MaxFALL                                  : 363 cd/m2
Video #2
Codec-ID                                 : dvhe
Dauer                                    : 3 h 16 min
Höhe                                     : 1 080 Pixel
ColorSpace                               : YUV
Default                                  : Nein
MaxCLL                                   : 1000 cd/m2
MaxFALL                                  : 363 cd/m2
Audio #1
Format                                   : DTS XLL
Codec-ID                                 : mp4a-A9
Dauer                                    : 3 h 16 min
Kanäle                                   : 6 Kanäle
Sprache                                  : Deutsch
Default                                  : Ja
Audio #2
Format                                   : DTS XLL
Codec-ID                                 : mp4a-A9
Dauer                                    : 3 h 16 min
Kanäle                                   : 8 Kanäle
Sprache                                  : Englisch
Default                                  : Nein
Audio #3
Codec-ID                                 : ac-3
Dauer                                    : 3 h 16 min
Bitrate                                  : 448 kb/s
Sprache                                  : Englisch
Default                                  : Nein
Hi SoNNiBoi, I didn't know that the TV could play DV using the two separated video tracks, however the audio will not be transferred to the a/v receiver in this scenario as the TV doesn't have eARC support. Am I correct about this?
bronan
Post by bronan »
superfans124 wrote: Sun Oct 20, 2019 6:24 pm
Général
Durée                                    : 2 h 23 min
Vidéo #1
Durée                                    : 2 h 23 min
Débit                                    : 74,3 Mb/s
Default                                  : Non
MaxCLL                                   : 1633 cd/m2
MaxFALL                                  : 114 cd/m2
Vidéo #2
Durée                                    : 2 h 23 min
Débit                                    : 64,2 kb/s
Default                                  : Non
Audio
Durée                                    : 2 h 23 min
Débit                                    : 640 kb/s
Canaux                                   : 6 canaux
Langue                                   : Français
Default                                  : Non
Yes, but I'm adding the original theatrical mono (Laserdisc PCM) to it so I have to remux regardless.
Slightly off topic and not sure if anyone cares but Kogan are now having a "Pre-Sale" on new Andriod TV's with Dolby Vision. The Aussie prices are:
  • Kogan 50" Smart HDR 4K LED Android TV = $449.99
  • Kogan 55" Smart HDR 4K LED Android TV = $499.99
  • Kogan 65" Smart HDR 4K LED Android TV = $799.99
Cheers!
superfans124
bronan wrote: Sun Oct 20, 2019 7:01 pm
ok, let's see. was the mono pcm demuxed with ffmpeg? in my limited experience, I found mp4box works better with media streams demuxed with ffmpeg, even better if all demuxed from the same source. I seem to have experienced similar end result when the audio track was not "marked" by ffmpeg, mp4box would report something "unusual" and the mp4 did not play.
alternatively, but this is only my brainstorming without first hand experience, would it be possible to mux the mono pcm into the main movie m2ts file with tsMuxer?
SoNNiBoi
Post by SoNNiBoi »
Smanet wrote: Sun Oct 20, 2019 6:29 pm
@Smanet unfortunately, you are right. I hope there will be a firmware update very soon to enjoy HD-Sound...
bronan
Post by bronan »
superfans124 wrote: Mon Oct 21, 2019 2:01 pm
bronan wrote: Sun Oct 20, 2019 7:01 pm Yes, but I'm adding the original theatrical mono (Laserdisc PCM) to it so I have to remux regardless.
There is no demuxing for laserdiscs since there is no real file structure, you have to capture the stream in real time. I was using tsmuxer before to export the video channels, so I'm trying out ffmpeg now to see if it makes any difference.
I thought about trying to make a new .m2ts with tsmuxer but unfortunately I'd have to resample the audio to 48kHz for it to accept it (LD is natively 44.1kHz). I did notice though that tsmuxer is open source now (yay!) so I might try to see if I can get around that restriction :)
Edit: It seems the point is moot since m2ts created by tsmuxer won't trigger Dolby Vision.
superfans124
bronan wrote: Mon Oct 21, 2019 6:03 pm
yikes, sorry, I wish I knew anything at all about the particular format to be of any help.
bronan
Post by bronan »
superfans124 wrote: Tue Oct 22, 2019 3:14 am
It's OK, its working fine for me streaming to the TV's Video app via DLNA so I'm happy enough with it (the TV outputs to amp so sound is fine). Thanks for the help anyways!
I am working on a Windows GUI app btw to simplify the remuxing process, will share when its ready
bobross
Post by bobross »
I've read all 44 pages of this thread. Wouldn't it just be best for someone to code an ISO player for the popular TVs? LG, Sony, etc...? And no I don't have the knowledge myself but it can't be that hard for someone with the skills. I see so many crap apps on my LD OLED, why can't someone just make an ISO playback app?
Post by SamuriHL »
Define "someone". And how you plan on getting said app onto those devices. Dolby could just as easily create an MKV spec for Dolby Vision, but, here we are....without one. They don't see any legit use cases for ISO or MKV, so, in order to protect the content of those who license their stuff, they don't....mp4 notwithstanding. This isn't about tech. It's about money.
Smanet
Post by Smanet »
SoNNiBoi wrote: Mon Oct 21, 2019 2:52 pm
I have read that LG has no intentions to introduce eARC for C8 series, which it not a big drama to me until we talk about Dolby Vision and lossless audio. But I have an eARC enabled A/V receiver, so that would be the perfect solution.
Update, it's even worse:
https://lgcommunity.us.com/discussion/3 ... r-lg-c8/p3
