Remove voice over
mg23gerard
Remove voice over
Post by mg23gerard » Sun Oct 20, 2019 9:53 am
How do I remove the voice over from a Blu-ray I'm converting?
Re: Remove voice over
Post by Woodstock » Sun Oct 20, 2019 3:19 pm
If you know that the track is called the Descriptive Audio Track, you can find how to select the correct audio track.
If you know in advance which track(s) DO want, Changing names with Expert mode enabled explains how to de-select them before ripping. Otherwise, the tools mentioned in the first topic can be used.
