Replicas
mike_mgoblue
Re: Replicas
#16 Post by mike_mgoblue » Thu Oct 17, 2019 5:58 am
d00zah wrote: Sun Oct 06, 2019 12:33 pm
mike_mgoblue wrote: Sun Oct 06, 2019 8:04 am The file listed as "Main Feature" that is 00593.mpls is wrong because it has the wrong number of chapters and the wrong length of time. Why is this listed as "Main Feature" when it is wrong in so many ways (i.e., the Chapter Count and the Duration of the movie)?
https://www.makemkv.com/forum/viewtopic.php?f=1&t=16791
Note the paragraph:
"If MakeMKV made an incorrect choice (it can happen), let Mike know about it - information on how to do that is found in the first link in this message."
Do you know if Mike saw my message above regarding Replicas and how I found the correct version? If I need to send a message to Mike, do you know if there is a spot I should do that?
Re: Replicas
#17 Post by d00zah » Thu Oct 17, 2019 10:45 am
mike_mgoblue wrote: Thu Oct 17, 2019 5:58 am
Note the paragraph:
Per the instructions here (referenced in above link):
https://www.makemkv.com/forum/viewtopic ... 158#p48158
you need to gather the necessary data & email to support. This doesn't necessarily mean you will get a direct response.
Frogpills
Re: Replicas
#18 Post by Frogpills » Fri Dec 20, 2019 1:29 am
just a fyi, following the codes listed on the first post, my copy's file was track 18... (Replicas_t18.mkv) and 00056.mpls
MattB1701
Re: Replicas
#19 Post by MattB1701 » Fri Jan 24, 2020 9:43 pm
Question - I see a retail version and a redbox version. What about a Netflix Blueray option or should this (and redbox) be just considered like a rental version and they are all the same?
///mjb
MudydyDogs
Re: Replicas
#20 Post by MudydyDogs » Tue Sep 15, 2020 9:14 am
Confirmation for the UK version (4K Ultra HD + Blu-ray + Digital Download) the correct version for the Blu-ray is
Title information
Source file name: 00474.mpls
Duration: 1:58:59
Chapters count: 16
Segment count: 15
Segment map: 503,504,501,502,515,508,509,505,514,513,512,506,511,507,510
File name: Anna_t56.mkv
I ripped this version and then parallel watched it with the download version. Perfect match :)
