Beta key expired
Beta key expired
The beta key is expired. Will there be a replacement? Thanks.
Re: Beta key expired
Hi!
Have you checked the "New and Announcemnts at?:
http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
setarip_old: although it says valid until october this key does not work. under both linux and windows.
ggking7: yes mike admin will replace the key soon, until then set your clock back a few days and it will work again.
- Contact:
Updated.
