Unable to Decrypt UHD Scarface Using LibreDrive
aarpcard
#1 Post by aarpcard » Wed Oct 16, 2019 2:07 pm
Not sure if I should post this here in on the LibreDrive page. This is all new to me to even-though I've read through this forum a lot, I'll probably make terminology mistakes and have gaps in my understanding of the processes.
I have an Asus BC-12D2HT drive that was manufactured in August of 2019. It came with the 3.00 version firmware on it. After doing some research I found that in order to use LibreDrive firmware/functionality I would need to upgrade it to the 3.01 MK firmware. I did this successfully and the drive still works and will rip various UHD discs using direct access mode.
However when I try to rip a UHD copy of Scarface I just bought when using LibreDrive direct access mode, I get the following error: "The volume key is unknown for this disc - video can't be decrypted."
The AACS versions listed in the dump filename is V65, whereas the latest version on my drive reported by MakeMKV is V68. I've already emailed the dump file to the support email address.
I thought that the LibreDrive direct access functionality was supposed to remove the possibility of AACS host revocation. Why is it failing with this disc?
Again, I'm really new to this so I'm probably missing something simple. Thanks for the patience.
Re: Unable to Decrypt UHD Scarface Using LibreDrive
#2 Post by d00zah » Wed Oct 16, 2019 3:16 pm
Probably beneficial to read the whole thing, but refer to the section 'How do I discover the key for a disc I have?' for this issue:
UHD FAQ
aarpcard
#3 Post by aarpcard » Wed Oct 16, 2019 3:50 pm
I guess my confusion stems from my impression that LibreDrive reads the raw data from the disk which MKV then converts into a .mkv file therefore bypassing the need for an AACS key.
Does it not work this way?
#4 Post by d00zah » Wed Oct 16, 2019 4:32 pm
[brain fart] Please disregard. See:
What is LibreDrive?
#5 Post by Woodstock » Wed Oct 16, 2019 4:35 pm
LibreDrive simply tells the drive to ignore restrictions. It doesn't affect encryption.
st4evr
#6 Post by st4evr » Wed Oct 16, 2019 4:53 pm
Same asked and discussed here:
https://www.makemkv.com/forum/viewtopic ... 925#p75925
and in multiple other threads. In short, LibreDrive is not a magic pill for AACS decryption.
rifer11
#7 Post by rifer11 » Tue Oct 24, 2023 4:35 am
Outragous. We are 1/5 th of the way into the 21st century and this crap still is going on. Stop Fix it. Or stop selling the product!!
R Rife
