I'm trying to downgrade my Asus BC-12D2HT drive (currently running firmware 3.11) using the "ultra hax0r" method but I keep getting the Write DRAM NG 05/24/00" error.
Anybody know what I'm doing wrong or if there is another method I could use?
Can't Downgrade ASUS BC-12D2HT
Re: Can't Downgrade ASUS BC-12D2HT
Try to crossflash as discussed in these threads:
https://www.makemkv.com/forum/viewtopic ... .11#p79424
https://www.makemkv.com/forum/viewtopic ... .11#p74646
As always, crossflashing comes with some risks. If you are unsure or inexperienced in this, you can also ask for/pay for flashing services here:
https://www.makemkv.com/forum/viewforum.php?f=20
@brrm77 Hello! how did you solve it in the end? I'm in a similar situation to yours.brrm77 wrote: Fri Oct 11, 2019 1:37 pm Hi,
Did you get your drive flashed?brrm77 wrote: Fri Oct 11, 2019 1:37 pm Hi,
