The Adventures of Rabbi Jacob (French version)
Happycy
This French UHD release of Louis de Funes' "Les Aventures de Rabbi Jacob" (released end September 2019) is "failing to open disk". As it is a French release and may not be picked up by others I will send the AACS dump file to the admin address mentioned in other posts.
Re: The Adventures of Rabbi Jacob (French version)
Do you have debug logging turned on? Are their error messages prior to the "failed to open disk"?
Happycy
Hi, the log appears as follows:
"MakeMKV v1.14.5 win(x64-release) started
Using LibreDrive mode (v05 id=F0ED16432FAA)
Downloading latest HK to C:\Users\[...]/.MakeMKV ...
Saved AACS dump file as C:\Users\[...]/.MakeMKV/MKB20_v61_BDROM_9FEA.tgz
Failed to open disc"
(Took out the user name and replaced by [...])
I sent the file MKB20_v61_BDROM_9FEA.tgz to the admin address.
Hope that was the info you were looking for.
Happycy
Now solved. Many thanks!
