The Adventures of Rabbi Jacob (French version)
Happycy
Post by Happycy »
This French UHD release of Louis de Funes' "Les Aventures de Rabbi Jacob" (released end September 2019) is "failing to open disk". As it is a French release and may not be picked up by others I will send the AACS dump file to the admin address mentioned in other posts.
Re: The Adventures of Rabbi Jacob (French version)
Do you have debug logging turned on? Are their error messages prior to the "failed to open disk"?
Happycy
Post by Happycy »
Hi, the log appears as follows:
"MakeMKV v1.14.5 win(x64-release) started
Using LibreDrive mode (v05 id=F0ED16432FAA)
Downloading latest HK to C:\Users\[...]/.MakeMKV ...
Saved AACS dump file as C:\Users\[...]/.MakeMKV/MKB20_v61_BDROM_9FEA.tgz
Failed to open disc"
(Took out the user name and replaced by [...])
I sent the file MKB20_v61_BDROM_9FEA.tgz to the admin address.
Hope that was the info you were looking for.
Happycy
Post by Happycy »
Now solved. Many thanks!
