UHD Failed decryption
solrac42
#1 Post by solrac42 » Mon Apr 22, 2019 12:49 pm
I have the latest 1.14.3 MakeMKV and I am using direct access to the server for hashed keys.
So far It is unable to decrypt DC Justice League, Star Wars The Last Jedi and Marvel AntMan and the Wasp. (all UHD)
They all failed with too many hash key errors, xxxx.m2ts file is corrupted.
Still Above Ground ...
extranet
Re: UHD Failed decryption
#2 Post by extranet » Mon Apr 22, 2019 2:17 pm
I know this doesn't help but I've ripped all of these so the issue is probably not MakeMKV. One thing you could try is to downgrade by downloading a previous version. I always keep an older version and to be honest I've been using it.
#3 Post by SamuriHL » Mon Apr 22, 2019 3:22 pm
Looks more like read errors. I would clean them with a microfiber cloth from the inside straight out to the edge all the way around the disc and try again. You don't provide what drive and firmware you're trying to read them with, and that information might help, as well.
solrac42
#4 Post by solrac42 » Mon Apr 22, 2019 3:28 pm
I am using a new LG BH16NS55 friendly drive with firmware downgraded to version 1.00 which works fine with all my other Marvel and DC 4K movies.
The discs are perfect with no marks or defects and are brand new.
Please let me know what ODD are you using and what firmware version ?
#5 Post by SamuriHL » Mon Apr 22, 2019 4:14 pm
I hear that all the time. "The discs are brand new, perfect condition" blah blah blah. LOL :) It doesn't matter. I've had MANY discs come directly out of the case into the drive that couldn't be read. A lot of them come with an invisible film on them that cause read errors. You gotta trust me and clean it with a microfiber cloth and try again. Every disc I've had that couldn't be read...every single one....I've done that to and was able to read it fine.
I have 2 different drives myself. An ASUS BW-16D1HT with MK 3.10 and an LG NS60 with MK 1.01. There are some discs that like one drive over the other. But, as I said, I've never had a problem once I microfiber cleaned them. Try it. What's the worst that can happen? It still doesn't read? But, there's a good chance it will.
solrac42
#6 Post by solrac42 » Tue Apr 23, 2019 2:25 pm
I tried your suggestion of cleaning the discs, but still no joy.
I have also tried the WH14NS40 firmware in my LG drive, (all versions) and this DC Justice League still won't copy.
Thanks for your advice, I had forgotten about cleaning new discs, unfortunately It did not work, the disc may have mastering errors on it.
In the past I have had success with faulty PC games discs installing correctly after cleaning.
I am going to watch it on my 4K player to see if plays all the way through without any digital artifacts, if not I can always return it as faulty and get another copy and try again.
#7 Post by SamuriHL » Tue Apr 23, 2019 4:04 pm
Faulty discs happen a lot unfortunately. They farm it out to cheap mfg's and whole batches of discs can end up being bad. If you can get a replacement for the disc, I'd recommend doing so for sure. I've been very lucky in that cleaning mine has always worked. And my NS60 has read literally everything I've thrown at it without fail. Luck of the draw...
corzamoon
#8 Post by corzamoon » Fri Oct 11, 2019 9:29 am
My Ant-Man (Australian disc - which I believe is the same as the US disc) keeps failing also. I've tried 5 different firmware types on my LG (Asus and LG firmware) and Ant-Man keeps failing. It's the only disc that's doing this though. I have cleaned it 3 times with microfiber cloth.
Should I try to get a replacement disc?
#9 Post by MartyMcNuts » Fri Oct 11, 2019 10:16 am
Firmware has nothing to do with it. Did you even read the error you were given?
I tried my aussie version today and the volume key is unknown. I submitted the dump file so hopefully Mike can work out the key in the next day or two.
corzamoon
#10 Post by corzamoon » Sun Oct 13, 2019 3:52 am
That's what I thought, but there were a couple of discs that had trouble on certain firmware, and then they worked fine on another... but Ant-Man is definitely not the case.
#11 Post by MartyMcNuts » Sun Oct 13, 2019 4:48 am
I decrypted my Ant-Man UHD yesterday as Mike has added the VUK. If yours is still not working, what error are you getting?
corzamoon
#12 Post by corzamoon » Sun Oct 13, 2019 5:00 am
Since the key has been added, it seems to be working now :)
#13 Post by MartyMcNuts » Sun Oct 13, 2019 5:18 am
So in future, if MakeMKV tells you that the vuk is unknown, make sure you submit the dump file that is generated and within a couple of days the vuk will be added and you will be able to decrypt the disc.
