My head hurts from this...
VegasMan
Been trying to wrap my head around the whole firmware downgrade or upgrade and how to exactly do it.
I read several threads, downloaded flashers and tried several firmware files...
no luck. Just errors...
There has to be a more noob guide on this or maybe I am missing something.
This is the drive I bought:
https://www.amazon.com/gp/product/B07BC ... UTF8&psc=1
The box says "MD-8107S-U3YC-UHD"
According to MakeMKV:
Product: BD-RE BU40N
Revision: 1.01
Firmware date: 2117-12-22 12:21
From what I understand these are LG drives really... just rebranded.
Anywho.... like I stated earlier, tried several flashers and firmwares.
Checksum errors, etc...
Any guidance would be sooooo appreciated at this point.
Revision: 1.01
Re: My head hurts from this...
Use the search function at the top of the page and search for "Archgon". You will find the info you require.VegasMan wrote: Tue Oct 08, 2019 9:54 pm Been trying to wrap my head around the whole firmware downgrade or upgrade and how to exactly do it.
Revision: 1.01
If you are really lazy and don't want to search for the info, use the ASUS flasher and flash BU40N 1.00 to your drive.
st4evr
VegasMan
I tried that.... both things... several hours later...
Wasn't lazy.
Did several searches and read several threads... tried several firmwares and flashers...
That firmware didn't load. Checksum error, etc...
Not sure why it didn’t work for you but everyone I have helped with the Archgon (Bu40n) has flashed Bu40n 1.00 firmware without issue using the modified asus flasher.VegasMan wrote: Wed Oct 09, 2019 5:59 amI tried that.... both things... several hours later...
Wasn't lazy.
Make sure that nothing is running in the background, such as anyDVD, dvdfab etc... Also, are you an administrator on your computer?
BlueMac77
- Contact:
Maybe you can provide more details on how you're applying the firmware to the drive or screenshots of the error messages so the experts here may be able to help. And some info on how the external slim drive is connected to your computer.VegasMan wrote: Wed Oct 09, 2019 5:59 am
Wasn't lazy.
VegasMan
Details as best I can:
The external drive info
Revision: 1.01
Connected via USB 3.0 on computer
Windows 10 (All updated and video card drivers updated)
I uninstalled all of the AnyDVD products because of this may be a conflict.
Only thing installed is MakeMKV.
The following links were provided on the forum for a basic guide to update the firmware.
Attempting to flash firmware using "BH14NS40_N1.00-A4_patched.exe" found on this link:
https://www.makemkv.com/forum/viewtopic ... 873#p70284
using the following firmware file "DE_LG BU40N_1.00.bin"
I get the following error no matter which firmware I try to use.
CheckSum is mismatched.
Drive will go to BOOT Mode
Please retry again
I tried other links but it was the FW changer which didn't even work at all, kept saying DeviceIoControl error: Error Code 121
That was the "ASUS_ODD_FW_Changer_(Modified).exe" file.
Please let me know if there is any additional information that could help anyone guide me through this process.
Revision: 1.01
Please retry again
The Issue is most likely the connection via USB. Not all interfaces support all necessary commands to flash your drive. You should connect it directly to your computer via SATA if you have the possibility. Then you can put it back to the USB connection.
VegasMan
This is the first I am hearing of this potential problem.
Even with my original post I give a link to the product being an external.
I didn't see anything about this being a problem with the instructions on flashing drives.
I guess I will do my best to take apart this external case and try to connect it via sata.
MattyB
same issues here and im scouring these forums for 2 hours trying to find any help and cant.
"CheckSum is mismatched.
Please retry again"
Please retry again"
A couple of suggestions:MattyB wrote: Fri Jul 01, 2022 5:07 pm same issues here and im scouring these forums for 2 hours trying to find any help and cant.
Please retry again"
- Pick a topic & post once. Spraying multiple topics w/ the same "it doesn't work" serves no purpose.
- Provide some helpful info...MakeMKV 'Drive/LibreDrive" info (it's text you can copy/paste), what, specifically, you've tried, so far, etc..
2 of you topics have gotten responses (besides this one).
MattyB
My apology, I thought it would email notify me of a response. Here's my info:
OS device name: F:
Revision: 1.02
Serial number: MO5LC2E5957
Bus encryption flags: 1F
Highest AACS version: 61
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Downloaded the Firmware Downgrade software from here (viewtopic.php?f=16&t=18873#p70284)
Downloaded the "all you need firmware pack" from there (https://drive.google.com/file/d/1HRnbXi ... sp=sharing)
Tried flashing the firmware that was specific for my drive (HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934)
And keep getting the same error "Checksum......."
OS device name: F:
Revision: 1.02
Nah that's old that's your issue use the updated guideMattyB wrote: Fri Jul 01, 2022 9:02 pm My apology, I thought it would email notify me of a response. Here's my info:
OS device name: F:
Revision: 1.02
