Midsommar
hvnphoto
Midsommar
#1 Post by hvnphoto » Tue Oct 01, 2019 5:28 pm
Title information
Source file name: 00915.mpls
Duration: 2:27:05
Chapters count: 16
Segment count: 15
Segment map: 511,512,501,509,506,504,508,514,515,507,502,505,503,513,510
File name: Midsommar_t190.mkv
Steveredrum
Re: Midsommar
#2 Post by Steveredrum » Tue Oct 01, 2019 10:45 pm
hvnphoto wrote: Tue Oct 01, 2019 5:28 pm Title information
Duration: 2:27:05
Chapters count: 16
Segment count: 15
Thanks that worked for me
lebelm
Re: Midsommar
#3 Post by lebelm » Tue Oct 08, 2019 1:07 pm
Does this work for Redbox version?
acidglaze
Re: Midsommar
#4 Post by acidglaze » Tue Oct 08, 2019 4:25 pm
My Redbox disc matches the same segment map.
Gojira74
Re: Midsommar
#5 Post by Gojira74 » Tue Oct 08, 2019 6:47 pm
My Redbox disc also has the same segment map associated with the same source file 00915.mpls, except the file name on the disc is different: Midsommar_t188.
I haven't checked if it plays correctly yet.
Update: I watched it, and it looks like it is all there in order. This movie is TERRIBLE to try and cruise for weird jumps because .... it's got them naturally. Looks alright to me.
Re: Midsommar
#6 Post by Woodstock » Tue Oct 08, 2019 9:52 pm
MakeMKV file name will change according to your settings for minimum title run time. MakeMKV only counts titles AT LEAST as long as your minimum, so someone using MTL=30 seconds and someone using MTL=1800 will have vastly different file numbers.
The on-disk file name, though, shown in the Info window, should match up.
Gojira74
Re: Midsommar
#7 Post by Gojira74 » Wed Oct 09, 2019 3:16 pm
So the XXX.MPLS should match is what you're saying, along with the segment numbers?
Re: Midsommar
#8 Post by Woodstock » Wed Oct 09, 2019 5:59 pm
Yes.
quornicus
Re: Midsommar
#9 Post by quornicus » Sat Oct 12, 2019 7:15 pm
Thanks for sharing this. I hadn't yet faced a fake-playlist disk, and this helped me understand the problem and what constitutes a solution.
