Lovely Rita
Post
by Lovely Rita » Sun Oct 06, 2019 9:34 pm
Due to a drive error, I'm in the process of rebuilding some of my library.
Discs in question, Avatar and Showtime series Homeland (all BD+ protected) were previously processed years ago. Now, receiving "fatal errors" during the "processing BD+ code" process.
Thought I would throw this out to the collective.....
I've reached out to
support@makemkv.com twice in the past 6 weeks, unfortunately with no reply.
Lovely Rita on Mon Apr 20, 2020 10:44 pm, edited 1 time in total.
Post
by Billycar11 » Mon Oct 07, 2019 3:25 am
Lovely Rita wrote: Sun Oct 06, 2019 9:34 pm
I've reached out to
try with java installed
Lovely Rita
Post
by Lovely Rita » Mon Oct 07, 2019 4:20 am
Billycar11 wrote: Mon Oct 07, 2019 3:25 am
I've had Java installed ever since Mike came out with his Java RE addition. 2+ years?
Verified, after your suggestion, with my John Wick 3 disc.
Using Java runtime from /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
Post
by Billycar11 » Mon Oct 07, 2019 4:44 am
Lovely Rita wrote: Mon Oct 07, 2019 4:20 am
so it now works once you pointed makemkv at java?
Lovely Rita
Post
by Lovely Rita » Mon Oct 07, 2019 10:23 am
Billycar11 wrote: Mon Oct 07, 2019 4:44 am
No, my point was that it’s always been pointed at Java.
After your initial post all I did was pop in Wick, which I knew would utilize java and it did. I did not go into preferences and repoint.
The BD+ discs still give fatal errors.
***This occurs on both my Mac (High Sierra) and Windows 7 boxes.
Post
by Woodstock » Mon Oct 07, 2019 2:21 pm
BD+ should not need Java; just the playlist obfuscation needs it. The BD+ "engine" is built into MakeMKV.
Lovely Rita
Post
by Lovely Rita » Mon Oct 07, 2019 3:04 pm
I'll wait to hear back from the BD+ guru...
Since it's occurring on both of my machines, I suspect the software.
I can see no other recent mentions of it from others but it seems most of the attention these days is related to UHD.
Geurtswebdesign
Post
by Geurtswebdesign » Wed Oct 16, 2019 4:32 pm
i have the same problems, sometimes it also stops in the middle of the process and only counts up the time but doesn't do anything else.
i think it's in the software because a couple of version before this i didn't have that problem.
Lovely Rita
Post
by Lovely Rita » Thu Oct 17, 2019 10:33 am
Yes, I agree that it’s something to do with this version.
I can see where I added Independence Day (BD+ disc) to my server last November so something has happened between then and present day.
BlueMac77
Post
by BlueMac77 » Thu Oct 17, 2019 8:31 pm
Lovely Rita wrote: Thu Oct 17, 2019 10:33 am
Hi Lovely Rita. Not sure if this will work, please try to reset your Mac’s “PRAM” if you have not done this yet. Luckily on my Mac, I did not get any “Fatal Error Program will now exit” error. I’m using MakeMKV 1.14.5 on Sierra. I have a Pioneer BDR-207DBK drive.
Lovely Rita
Post
by Lovely Rita » Thu Oct 17, 2019 10:32 pm
BlueMac77 wrote: Thu Oct 17, 2019 8:31 pm
It’s not a Mac issue as the same thing happens on my PC.
Thanks!!
sheik124
Post
by sheik124 » Sun Oct 20, 2019 7:42 pm
Hey Rita, I just ran into this issue for the first time with my first BD+ discs today. I kept getting the same exact error as you.
I went to C:\Program Files (x86)\MakeMKV and then right clicked "makemkv.exe" and "Run as Administrator" - the error went away and it was able to finish processing the BD+ code. Have you tried that yet?
gamereviewgod
Post
by gamereviewgod » Mon Oct 21, 2019 7:41 pm
Just tried running as admin and it's still giving me the error. I was able to rip Scarface's 4K, but not It's a Wonderful Life or Wizard of Oz.
digimars
Post
by digimars » Sun Oct 27, 2019 3:25 pm
I'm having the same exact problem today on my disc for "The Omen". I'm on Debian 10, and running the latest MakeMKV (compiled per instructions). This is the only disc that I have ever received this error on. I have ripped multiple titles the last couple of days, this is the first time I'm seeing it.
Just for grins and giggles, I ran MakeMKV again using sudo (which you should really NEVER do), and it worked just fine on this disc. There is something about the BD+ access permissions on this build I guess?
nitro322
Post
by nitro322 » Mon Dec 16, 2019 4:16 am
I also have the same problem, with John Wick 3. Running 1.14.7 on Linux with OpenJDK 1.8.0_222 installed. Tried running via sudo as digimars suggested, but still encountered the same error.
Edit: Installing 11.0.5 seemed to do the trick. Weird that a newer version of Java is required for John Wick 3 - it's not likely that the vast majority of blu-ray players out there are still actively receiving firwmare updates containing new versions of Java.
