~HaMMeR~
Posts: 17 Joined: Fri Mar 16, 2018 4:56 pm
Post
by ~HaMMeR~ » Sat Oct 05, 2019 1:56 pm
SamuriHL wrote: ↑ Sat Oct 05, 2019 1:53 pm
Mike said it should be fixed in another thread.
Link to the other thread?
Just tried and still says Automatic HK downloading is disabled or failed
edit: downloaded the latest hashed keys file that was made available today and it's now working with a new release (Gremlins). Thanks Mike!
watts
Posts: 5 Joined: Wed Oct 02, 2019 8:30 pm
Post
by watts » Sat Oct 05, 2019 2:04 pm
Working for me too. Thanks mike!
demon
Posts: 133 Joined: Sat Dec 20, 2014 7:06 am
Post
by demon » Sat Oct 05, 2019 2:25 pm
Working here, the discs that had been failing are now succeeding.
shanedag
Posts: 3 Joined: Sat Jul 28, 2018 8:42 pm
Post
by shanedag » Sat Oct 05, 2019 2:26 pm
Can someone share the link to the post with the fix?
watts
Post
by watts » Sat Oct 05, 2019 2:34 pm
No specific fix. It just appears to work now, so probably something on the server end was fixed.
Posts: 2305 Joined: Mon Jun 14, 2010 5:32 pm
Post
by SamuriHL » Sat Oct 05, 2019 2:36 pm
He also released an updated hash key file. Look in the uhd disc section at the sticky.
Posts: 1512 Joined: Mon Jun 06, 2016 8:23 pm
Post
by d00zah » Sat Oct 05, 2019 2:36 pm
shanedag wrote: ↑ Sat Oct 05, 2019 2:26 pm
It's automatic, assuming that 'Allow contacting web...' is checked in 'Preferences > General' (& nothing else is blocking access).
d00zah on Sat Oct 05, 2019 2:48 pm, edited 1 time in total.
demon
Post
by demon » Sat Oct 05, 2019 2:42 pm
As mentioned, you don't need to download or do anything in particular. The update file just points to a hostname that resolves now.
ix400
Posts: 10 Joined: Thu Jun 02, 2016 9:47 am
Post
by ix400 » Sat Oct 05, 2019 6:17 pm
... such a pity that I can not test this, I am on holiday until the 16th....
Glad to hear that it seems to be fixed now.
mkvman1000
Posts: 17 Joined: Fri Oct 04, 2019 12:54 am
Post
by mkvman1000 » Sat Oct 05, 2019 10:57 pm
Issue is resolved for me. Thanks!
Someguy1234
Posts: 91 Joined: Tue Jan 29, 2019 2:48 am
Post
by Someguy1234 » Sun Oct 06, 2019 1:20 am
I'm getting this issue and I've even gone as far to disable my Firewall temporarily, with no luck. I get this error, over and over:
MakeMKV v1.14.5 win(x64-release) started
Using LibreDrive mode (v05 id=DA23CAE0BD2F)
Downloading latest HK to D:/MakeMKV ...
Saved AACS dump file as D:/MakeMKV/MKB20_v68_The_Shining_53F0.tgz
Posts: 10124 Joined: Sun Jul 24, 2011 11:21 pm
Post
by Woodstock » Sun Oct 06, 2019 2:04 am
Be aware that some internet providers will cache DNS data for longer than they should, and sometimes your operating system will do the same.
On Windows, the command ipconfig /flushdns will tell the system to flush its DNS cache. How you do it on other operating systems can be found by searching for "flush dns cache" + your operating system.
When I was creating new domains on a regular basis, I could have it active within 20 minutes of finishing the registration... except for people on AOL, which would take 24 hours.
VarHD
Posts: 87 Joined: Thu Apr 04, 2019 4:40 pm
Post
by VarHD » Sun Oct 06, 2019 11:51 am
Flushing the DNS cache didn't help in my case. I'm still getting the "Automatic HK downloading is disabled or failed." error.
What is the exact URL/domain that the app is using to pull this data from?
Post
by d00zah » Sun Oct 06, 2019 11:59 am
VarHD wrote: ↑ Sun Oct 06, 2019 11:51 am
It's all covered earlier in this very thread.
