MakeMKV v1.14.5 win(x64-release) started
Downloading latest SDF to G:/FILES ...
Automatic SDF downloading is disabled or failed.
Title #00008.mpls(2) has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00010.mpls was added as title #0
File 00001.mpls was added as title #1
File 00000.mpls was added as title #2
Title #00008.m2ts has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00018.m2ts was added as title #3
Title #00014.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00010.m2ts was added as title #4
Saving 1 titles into directory G:/FILES
AV synchronization issues were found in file 'G:/FILES/Journey to the Beginning of Time_t01.mkv' (title #2)
AV sync issue in stream 1 at 0:05:00.040 with duration of 285.025s : 57005 overlapping frame(s) dropped at segment boundary
