Ocean's Thirteen (Widescreen Edition)
Traepoint
Post by Traepoint » Fri Oct 04, 2019 3:08 pm
MakeMKV v1.14.5 win(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS40 1.03' at offset '1048576'
LibreDrive firmware support is not yet available for this drive (id=76CF63BADB03)
Title #1 was added (34 cell(s), 2:01:44)
Title #2 has length of 12 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #3 has length of 12 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #4 has length of 21 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #5 has length of 7 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #6 was added (1 cell(s), 0:22:46)
Title #7 has length of 274 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #8 has length of 497 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #9 has length of 144 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Subtitle stream #6 is identical to stream #4 and was skipped
Subtitle stream #7 is identical to stream #4 and was skipped
Saving 1 titles into directory F:/Plex Burns/Movies
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '2988781568'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '2988781568'
Failed to save title 0 to file F:/Plex Burns/Movies/Ocean's Thirteen (2007).mkv
0 titles saved, 1 failed
Traepoint
Re: Ocean's Thirteen (Widescreen Edition)
Post by Traepoint » Sat Oct 05, 2019 4:20 pm
I tried this DVD on a older PC and it worked fine.
Post by Woodstock » Sat Oct 05, 2019 8:32 pm
Was the older PC's drive "just" a DVD drive? Some DVDs aren't readable in Bluray drives, because of the difference in the laser.
