"automatic sdf downloading is disabled or failed" while decrypting
~HaMMeR~
#46 Post by ~HaMMeR~ » Sat Oct 05, 2019 1:56 pm
SamuriHL wrote:
Sat Oct 05, 2019 1:53 pm
Mike said it should be fixed in another thread.
Link to the other thread?
Just tried and still says Automatic HK downloading is disabled or failed
edit: downloaded the latest hashed keys file that was made available today and it's now working with a new release (Gremlins). Thanks Mike!
watts
Re: "automatic sdf downloading is disabled or failed" while decrypting
#47 Post by watts » Sat Oct 05, 2019 2:04 pm
Working for me too. Thanks mike!
demon
#48 Post by demon » Sat Oct 05, 2019 2:25 pm
Working here, the discs that had been failing are now succeeding. 👍
shanedag
#49 Post by shanedag » Sat Oct 05, 2019 2:26 pm
Can someone share the link to the post with the fix?
watts
#50 Post by watts » Sat Oct 05, 2019 2:34 pm
No specific fix. It just appears to work now, so probably something on the server end was fixed.
#51 Post by SamuriHL » Sat Oct 05, 2019 2:36 pm
He also released an updated hash key file. Look in the uhd disc section at the sticky.
#52 Post by d00zah » Sat Oct 05, 2019 2:36 pm
It's automatic, assuming that 'Allow contacting web...' is checked in 'Preferences > General' (& nothing else is blocking access).
demon
#53 Post by demon » Sat Oct 05, 2019 2:42 pm
As mentioned, you don't need to download or do anything in particular. The update file just points to a hostname that resolves now.
ix400
#54 Post by ix400 » Sat Oct 05, 2019 6:17 pm
... such a pity that I can not test this, I am on holiday until the 16th....
Glad to hear that it seems to be fixed now.
mkvman1000
#55 Post by mkvman1000 » Sat Oct 05, 2019 10:57 pm
Issue is resolved for me. Thanks!
Someguy1234
#56 Post by Someguy1234 » Sun Oct 06, 2019 1:20 am
I'm getting this issue and I've even gone as far to disable my Firewall temporarily, with no luck. I get this error, over and over:
MakeMKV v1.14.5 win(x64-release) started
Using LibreDrive mode (v05 id=DA23CAE0BD2F)
Downloading latest HK to D:/MakeMKV ...
Saved AACS dump file as D:/MakeMKV/MKB20_v68_The_Shining_53F0.tgz
#57 Post by Woodstock » Sun Oct 06, 2019 2:04 am
Be aware that some internet providers will cache DNS data for longer than they should, and sometimes your operating system will do the same.
On Windows, the command ipconfig /flushdns will tell the system to flush its DNS cache. How you do it on other operating systems can be found by searching for "flush dns cache" + your operating system.
When I was creating new domains on a regular basis, I could have it active within 20 minutes of finishing the registration... except for people on AOL, which would take 24 hours.
VarHD
#58 Post by VarHD » Sun Oct 06, 2019 11:51 am
Flushing the DNS cache didn't help in my case. I'm still getting the "Automatic HK downloading is disabled or failed." error.
What is the exact URL/domain that the app is using to pull this data from?
#59 Post by d00zah » Sun Oct 06, 2019 11:59 am
It's all covered earlier in this very thread.
VarHD
#60 Post by VarHD » Sun Oct 06, 2019 1:01 pm
Earlier https://www.makemkv.com/svq/sdf.bin was mentioned, but is that the exact same URL that the app uses?
I can access this URL today and could yesterday, I even downloaded that file and put it into the data folder, but it didn't help.
Also http://www.hkdatastore.tk/ was mentioned before that. This one points to "server not found" for me, but is that a whole separate site or a domain that forwards to https://www.makemkv.com/svq/sdf.bin?
Locked
