MakeMKV 1.6.0 Fatal Error at Start
maddogatc
Post by maddogatc »
MakeMkv Fatal error at start up of program. Tried reinstalling the program a number of times in different folders and tried different compatibility settings and nothing works. Ver 1.5.8 worked with no problems. Both were run on Windows 7 Pro 64 bit. I ran 1.6.0 on my laptop with vista home 32 bit and it worked fine. Tried older version and it will not run as it says newer version available. Any ideas?
Re: MakeMKV 1.6.0 Fatal Error at Start
Post by mike admin »
Please try the following - start a command prompt, navigate to the folder where MakeMKV is installed and type
cmd /c set APROXY_FORCE_32BIT=1 && makemkv
. Please post the result here.
beamer234
Post by beamer234 »
I?ve tried this:
the following happens:
The application window opens, after about 5 sec
it closes with the massage:
"Fehler aufgetreten, Programm wird beendet"
"Error occurred, program will be terminated"
beamer 234
