Automatic SDF/HK downloading is disabled or failed messages
jcgriff
Post by jcgriff » Fri Oct 04, 2019 8:30 pm
I've started receiving "Automatic SDF downloading is disabled or failed" and "Automatic HK downloading is disabled or failed" on UHD disks for some reason. Got it on new disks Spiderman Far From Home and MIB International so I tried a disk I had already backed up successfully, Hunter Killer and it still happened. Tried stopping firewall, uninstall/reintall, different versions and same result. Any ideas? Regular Blu-rays are fine.
MakeMKV v1.14.5 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\John/MakeMKV_log.txt
Downloading latest SDF to C:\Users\John/.MakeMKV ...
Automatic SDF downloading is disabled or failed.
DEBUG: Code 96 at %.rR&vsq2cI<A6cT:29407040
Using LibreDrive mode (v05 id=62194E19F4EC)
Downloading latest HK to C:\Users\John/.MakeMKV ...
DEBUG: Code 0 at %.rR&vsq2cI<A6cT:213135688
Saved AACS dump file as C:\Users\John/.MakeMKV/MKB20_v66_Hunter_Killer_35CD.tgz
DEBUG: Code 0 at E"`0L*bjuZ+[XW`":29396092
DEBUG: Code 0 at E"`0L*bjuZ+[XW`":29395172
OS device name: J:
Product: BD-RE WH16NS40
Revision: 1.02
Serial number: SIK95H4HG453
Firmware date: 2117-03-10 16:50
Highest AACS version: 66
Firmware version: 1.02
Disc Information
Label: HUNTER_KILLER
Timestamp: 2018-11-20 14:29:45
Data capacity: 74.24 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
ekpen
Re: Automatic SDF/HK downloading is disabled or failed messages
Post by ekpen » Mon Oct 07, 2019 6:14 pm
I am having same issue since Saturday.
I pinged the 208 XXXX address, looks ok, then I tried Windows diagnostic .
It says the hkdatastore.tk is online, but not responding, probably due to firewall etc.
Thanks.
George.
Post by SamuriHL » Mon Oct 07, 2019 9:27 pm
There appear to be lots of DNS issues. See the link I posted just before your post as people have been discussing the issue there.
ekpen
Post by ekpen » Tue Oct 08, 2019 5:24 am
Greetings;
I am ripping now .
I followed the workaround.
Thanks.
George.
Someguy1234
Post by Someguy1234 » Tue Oct 08, 2019 7:00 pm
I'd suggest folks just change their DNS settings to Google's instead of doing it through your ISP, as that can take up to 20 hours. I did that and it fixed it immediately. I dunno what caused this DNS issue. It's strange and about drove me bonkers. :lol:
doktorg
Post by doktorg » Sun Oct 12, 2025 12:40 am
I was able to fix this by doing something incredibly stupid. (as I often do)
I disabled my VPN (Norton) for the duration of the initial disc read.
I do NOT endorse this as a fix, but I wanted to see if removing one factor would improve the download response.
