dt. edition J.Wick 3
Hello, I'm a newbie here. Unfortunately, with little English knowledge. Question. What about the German edition of J.Wick 3? Unfortunately it does not work at the moment. I sent the dump file to Mike.
thanks
thanks
Re: dt. edition J.Wick 3
Do you have the error log turned on?
If so, what is the exact error you are getting and/or can you post the error log?
When was the dump submitted to Mike? Weeks ago or days ago?
Simply saying "it does not work" makes it very difficult for anyone in any online forum to advise. We are not mind readers in this forum nor are we sitting next to you to help. So, help us help you and provide any relevant and detailed information regarding what you are seeing on your end, so that someone can advise if possible.
Error log? I think so. The log is generated. The log.text. and tgz files I handed over a few days ago svq@makemkv.com Or what do you mean?
Unfortunately, it remains message
Volume key unknown. Opening the disc failed
AACS Ausgabedatei als C:/tsMuxer/MKB20_v71_John_Wick_Kapitel_3_7EE0.tgz gesichert
Der Volumenschlüssel für die DVD/Blu-ray ist unbekannt - das Video kann nicht entschlüsselt werden
DEBUG: Code 0 at E"`0L*bjuZ+[XW`":29396092
DEBUG: Code 0 at E"`0L*bjuZ+[XW`":29395172
DEBUG: Code 233 at XotNAlgwwSEzOLe8EW/oywa7:0
DEBUG: Code 233 at i7Zx3pGKMdf8E7Mfjvc8PBo8:0
DEBUG: Code 233 at BIjN2+KsnprctBnT0JM19eYk:0
DEBUG: Code 233 at umfFRHNMdW8DlwvWPBlTj8kr:0
DEBUG: Code 233 at B/DGI5xWWFHrS5msAwpn/5um:0
DEBUG: Code 233 at Jamx6JUt/eqvR2KwyNvH5LCE:0
DEBUG: Code 233 at 7KZ7ShNR1xgKvP7Wnpu/7v/3:0
DEBUG: Code 233 at YEBYA35ViC2A8AYDqrzqLR4V:0
DEBUG: Code 233 at 1FOYi2AQzDsY7Cu9txNQlbRD:0
DEBUG: Code 233 at noawGVDLk32O+V982XhUH85N:0
Das Öffnen der Disk schlug fehl
Right now there is a problem with the automatic key updating.
This topic has discussion on the problem, and includes the link to manually download the key file:
viewtopic.php?f=1&t=17848&p=64938
Hey there!
Is there a solution yet?
I also have the german UHD disk ....also manually downloading the key file doenst work....
Unfortunately I find in your link no access to manual download current keys.Woodstock wrote: ↑Fri Oct 04, 2019 6:49 pmRight now there is a problem with the automatic key updating.
- Contact:
All should be fixed now
