SamuriHL wrote: Fri Nov 15, 2019 11:13 am
Do you want to document pulling one of these apart and cleaning it for people? I suspect that process would make people nervous if they've never done it before.
Sure maybe I'll start a UHD drive troubleshooting thread
But for now the basic process is:
Eject the tray while powered or the emergency eject port
Disconnect drive
Pop off the drive bezel not tray bezel 3 clips 2 on sides and 1 bottom just leave it hanging on tray it can't come off unless you remove tray bezel or tray
Remove 4 screws on the bottom
Flip back over and lift the top straight up it can take some jiggling and pulling out on the sides a bit
You then have access the laser right away
Assemble in reverse order
Or if you have a BU40N eject the tray and you can clean the laser right there lol it's part of the tray
Additional info
the disk hold down mechanism is part of the top case so you can not run disks without the case on unless your an ultra haxor
The bottom of the case has thermal pads if you remove it make sure they go back
Don't do
Ultra haxor junk:
The drive hold down mechanism removes from the top of the drive under the sticker not from inside the case it is a simple plastic disk with a pice of medal in it to stick to the magnetic drive motor head so the disk does not slip or fly off.
