Spider-Man Far From Home
Kevinicus
Re: Spider-Man Far From Home
#16 Post by Kevinicus » Fri Oct 04, 2019 3:04 am
rbphelan wrote: Fri Oct 04, 2019 2:03 am
Kevinicus wrote: Fri Oct 04, 2019 1:55 am Curious if anyone has had success yet?
Yes
Which version?
dandiodati
#17 Post by dandiodati » Fri Oct 04, 2019 5:53 am
I'm also having an issue to burn this UHD disk.
I did notice that it is saying HK failing to download, but I have not changed anything and was working before.
Is there any log to indicate if the request is getting blocked ? I have the windows firewall turned off and my router is not blocking anything.
SeaWolf
#18 Post by SeaWolf » Fri Oct 04, 2019 12:53 pm
Still not working for me. Standard retail version.
demon
#19 Post by demon » Fri Oct 04, 2019 2:04 pm
Worked for me, unlike a few others I bought this week.
Kevinicus
#20 Post by Kevinicus » Fri Oct 04, 2019 5:30 pm
SeaWolf wrote: Fri Oct 04, 2019 12:53 pm
Nor for me last night. Also standard retail (from Target). I sent in my log in case Mike doesn't have the right one yet.
enkita50
#21 Post by enkita50 » Fri Oct 04, 2019 6:45 pm
Hi all, I'm in the same boat at the moment. I bought the standard retail versions of Far From Home, Dr. Strange, Guardians of the Galaxy and Ant-Man but had no luck on any of them. I did send the dump files to support a couple days ago. I ended up downloading the free trial of DVDFab and surprisingly I was able to get each disk converted into MKV. I do like MakeMKV much better then anything DVDFab offers, and 9.5x out of 10, MakeMKV is much faster than any of the others to open the UHD disks.
makememe
#22 Post by makememe » Fri Oct 04, 2019 6:58 pm
recommend you check out, viewtopic.php?f=1&t=17848
there is an issue with the hk download for the lastest keys.
I, too, am unable to rip; I submitted the dump, but get the hk download fail.
EDIT: removed non-sense regarding sdf.bin. apologies.
darkedgex
#23 Post by darkedgex » Sat Oct 05, 2019 2:01 am
Welp, I'm on my third disc after having exchanged it, and except for one time where it recognized the disc (but couldn't actually read it with "Open disc"), it's as if I'm inserting a piece of plastic with a hole in the middle and it shows as "No disc inserted". I'm using an ASUS drive, is there a better drive I should be trying?
PaulCB
#24 Post by PaulCB » Sat Oct 05, 2019 8:10 am
Looks like Mike has gotten it added as my 'standard' disc from Walmart just started working so it is worth giving your rips a shot again.
Kevinicus
#25 Post by Kevinicus » Sat Oct 05, 2019 3:18 pm
PaulCB wrote: Sat Oct 05, 2019 8:10 am Looks like Mike has gotten it added as my 'standard' disc from Walmart just started working so it is worth giving your rips a shot again.
Works for me now too.
wschmitt55
#26 Post by wschmitt55 » Tue Oct 08, 2019 12:01 am
Works for me too!!!
Thanks very much for the support and updates. :D
tg_scooter
#27 Post by tg_scooter » Sun Oct 13, 2019 12:57 pm
I was still having trouble opening this one. But I finally got it to open today. Here's what I did,
-flushed my DNS server (Not sure if you need to do this)
-Updated my DNS to Google's DNS = https://developers.google.com/speed/pub ... docs/using
-restarted my PC (again, not sure if you need to do this)
-retried to open the disc
Voila!
VetteManiac
#28 Post by VetteManiac » Tue Oct 15, 2019 2:56 am
I tried to rip it tonight and everything looks great. Then when I start to click off the check marks on the left of the titles to make choices what I want to rip they all go away and the program says no disc inserted. I've done this a couple times and it just's repeats the same problem.
#29 Post by Billycar11 » Tue Oct 15, 2019 6:48 am
VetteManiac wrote: Tue Oct 15, 2019 2:56 am I tried to rip it tonight and everything looks great. Then when I start to click off the check marks on the left of the titles to make choices what I want to rip they all go away and the program says no disc inserted. I've done this a couple times and it just's repeats the same problem.
do the usual clean the disk and see what happens
VetteManiac
#30 Post by VetteManiac » Wed Oct 16, 2019 11:08 pm
Billycar11 wrote: Tue Oct 15, 2019 6:48 am
I cleaned it prior to my initial posting and it looked pristine. I tried cleaning it last night after I read your post and Makemkv couldn't read it. I opened the drive, looked at the disc, put it back in and it worked. It's almost like I needed a special sequence of events to happen before it would work.
