Beta key
Locked
Daskew78
Beta key
#1 Post by Daskew78 » Mon Sep 30, 2019 9:56 pm
Is there a new beta key available as the current one has run out and keeps popping up?
https://www.makemkv.com/forum/viewtopic.php?f=5&t=1053
Regards
Dave
st4evr
Re: Beta key
#2 Post by st4evr » Mon Sep 30, 2019 11:06 pm
As it has been the case for 10+ years, Mike will update the key at end/beginning of the month after expiration once he has a moment. Beta key users have to wait till then.
Daskew78
Re: Beta key
#3 Post by Daskew78 » Mon Sep 30, 2019 11:39 pm
It's the first time i've had a used one run out so forgive me for not knowing when it's not documented it gets updated at the end of the month.
Regards
Dave
Re: Beta key
#4 Post by d00zah » Mon Sep 30, 2019 11:43 pm
Search is your friend...
https://www.makemkv.com/forum/search.ph ... xpired+key
koberulz
Re: Beta key
#5 Post by koberulz » Tue Oct 01, 2019 6:22 am
Why do you need a beta key to rip DVDs if that's supposed to be free functionality?
JDLemon
Re: Beta key
#6 Post by JDLemon » Tue Oct 01, 2019 6:32 am
Honestly i wish i could afford the cost to buy right now as the software is worth it. Being on a low fixed income sucks. I am in the same boat waiting but knowing it will come.
T'hain Esh Kelch
Re: Beta key
#7 Post by T'hain Esh Kelch » Thu Oct 03, 2019 5:27 am
It is not. The application will be pay-to-use once it goes out of beta.
koberulz
Re: Beta key
#8 Post by koberulz » Thu Oct 03, 2019 5:47 am
The DVD functionality is supposed to be free, only the BD functionality is part of the beta.
Re: Beta key
#9 Post by Woodstock » Thu Oct 03, 2019 1:42 pm
What few are considering is the fact that, as a beta program, it changes on a regular basis to keep up with copy protection. The expiring key is intended to encourage you to check for newer versions.
In the old days, new versions were issued more frequently than every 60 days, and new versions had new keys.
Mtenga
Re: Beta key
#10 Post by Mtenga » Thu Oct 03, 2019 4:31 pm
The program already tells you if a newer version is available when you load it. No need to expire a key for that.
NoLifeDGenerate
Re: Beta key
#11 Post by NoLifeDGenerate » Thu Oct 03, 2019 4:36 pm
Exactly. It's stupid, and where the hell is the October code!?
musictrivianut
Re: Beta key
#12 Post by musictrivianut » Thu Oct 03, 2019 9:01 pm
Entitled and impatient much?
Daskew78
Re: Beta key
#13 Post by Daskew78 » Thu Oct 03, 2019 9:04 pm
:lol: :lol: :lol:
Regards
Dave
deadlift655
Re: Beta key
#14 Post by deadlift655 » Fri Oct 04, 2019 5:41 am
I wish they would make it easier to purchase the software! :D I got to spend about half an hour on the phone with my credit card company when I tried to purchase the software ages ago. The payment wouldn't go through for some reason. :roll: I haven't tried recently though.
strubdog
Re: Beta key
#15 Post by strubdog » Fri Oct 04, 2019 10:17 am
Patience is a virtue
Locked
