The Shining (1980) - Cannot Be Decrypted
stuckinkodiagain
The newly-released UHD blu-ray of Stanley Kubrick's "The Shining" (1980) cannot be decrypted in the latest version of MakeMKV. (This copy was purchased from Best Buy online, arrived a day early.) I've submitted the dump file to svq@makemkv.com.
Thanks as always to the developers!
Someguy1234
Re: The Shining (1980) - Cannot Be Decrypted
I've submitted the dump file as well. Let's hope they get it readable.
Also, did anyone else ever notice they NEVER fixed STAND BY ME on 4K? I've submitted it multiple times. What gives on that?
https://www.makemkv.com/forum/viewtopic ... 12&t=20244Someguy1234 wrote: Tue Oct 01, 2019 9:48 pm I've submitted the dump file as well. Let's hope they get it readable.
st4evr
And to add to d00zah's reply, AACS 2.1 and titles affected have been discussed in detail in this forum. Forum search function works, use it. Will often save you time and answer many questions.Someguy1234 wrote: Tue Oct 01, 2019 9:48 pm Also, did anyone else ever notice they NEVER fixed STAND BY ME on 4K? I've submitted it multiple times. What gives on that?
https://www.makemkv.com/forum/search.ph ... tand+by+me
https://www.makemkv.com/forum/search.ph ... s=aacs+2.1
Someguy1234
Thanks for those links in regards to that, you two. Appreciated it. I felt since it was also Stephen King it was related enough.
Someguy1234
Do you think that THE SHINING on 4K might also be this type (AACS 2.1)?st4evr wrote: Tue Oct 01, 2019 10:44 pmAnd to add to d00zah's reply, AACS 2.1 and titles affected have been discussed in detail in this forum. Forum search function works, use it. Will often save you time and answer many questions.Someguy1234 wrote: Tue Oct 01, 2019 9:48 pm Also, did anyone else ever notice they NEVER fixed STAND BY ME on 4K? I've submitted it multiple times. What gives on that?
stuckinkodiagain
It's not. MakeMKV can detect the AACS version. The Shining UHD is NOT AACS 2.1.Someguy1234 wrote: Wed Oct 02, 2019 2:38 amDo you think that THE SHINING on 4K might also be this type (AACS 2.1)?st4evr wrote: Tue Oct 01, 2019 10:44 pmAnd to add to d00zah's reply, AACS 2.1 and titles affected have been discussed in detail in this forum. Forum search function works, use it. Will often save you time and answer many questions.Someguy1234 wrote: Tue Oct 01, 2019 9:48 pm Also, did anyone else ever notice they NEVER fixed STAND BY ME on 4K? I've submitted it multiple times. What gives on that?
Someguy1234
Oh yeah, right on. Thanks for pointing that out.stuckinkodiagain wrote: Wed Oct 02, 2019 3:02 amIt's not. MakeMKV can detect the AACS version. The Shining UHD is NOT AACS 2.1.Someguy1234 wrote: Wed Oct 02, 2019 2:38 amDo you think that THE SHINING on 4K might also be this type (AACS 2.1)?st4evr wrote: Tue Oct 01, 2019 10:44 pm
1wayjonny
Anyone have luck ripping this yet along with all the other Tuesday releases?
demon
Negatory, still getting "Backup failed", and haven't seen a hashed-keys update this week.
demon
Backup is succeeding for me now. Thanks mike!
Someguy1234
It's still giving me this:
MakeMKV v1.14.5 win(x64-release) started
Using LibreDrive mode (v05 id=DA23CAE0BD2F)
Downloading latest HK to D:/MakeMKV ...
Saved AACS dump file as D:/MakeMKV/MKB20_v68_The_Shining_53F0.tgz
1wayjonny
Awesome working for me now too.
Looks like the program failed to download the update. firewall? running from a different dir? something else?
Looks like it tried though. Good luck
rbphelan
Working for me as well. Thanks again Mike!
Someguy1234
I have it checked and I've gone back and disabled and re-enabled it but still having no luck.archer wrote: Sun Oct 06, 2019 12:48 amDouble check that "Allow contacting web server for updates" in Preferences in MakeMKV is checked.Someguy1234 wrote: Sat Oct 05, 2019 10:54 pmIt's still giving me this:
