Can it work Blue Ray Drive BDDVDRW CH30N
Darwin
Post by Darwin »
Finally getting around to working on my blue ray collection and I purchased anew drive based of an amazon review and I cannot get it to work with MakeMKV, below is my output of the drive. I've been reading the forums all morning and I need to know am I SOL with this drive? or is there a custom firmware I can apply to it?
Product: BDDVDRW CH30N
Revision: AS00
Firmware date: 2113-06-14 14:59
Bus encryption flags: 1E
Drive platform: MT1939
Harware support: Yes
Firmware support: No
Firmware version: 0.AS00S
DVD all regions: Possible, not yet enabled
BD raw data read: Possible, not yet enabled
BD raw metadata read: Possible, not yet enabled
Any Help would be greatly appricated.
oddeyeball
Re: Can it work Blue Ray Drive BDDVDRW CH30N
Post by oddeyeball »
What exactly is happening or error you get when you put a disc in?
st4evr
Post by st4evr »
Did you purchase this drive from a third party seller on Amazon?
Are you positive this drive is brand new and unused?
That model appears to be a very old model (6+ years) previously bundled with Dell PCs. You might have just gotten ripped off on that purchase.
Darwin
Post by Darwin »
I bought this supposedly new on Amazon. When a disk is inserted it doesn't detect it. I've tried several DVDs and Blu Rays with the same effect. The output in my original post is all I get.
st4evr
Post by st4evr »
Darwin wrote:
Tue Oct 01, 2019 11:52 pm
When you insert a DVD or BD, without MakeMKV running, does your operating system (Windows, macOS, Linux) see the discs as present in the drive?
Do other apps (e.g. Windows Media Player, VLC, PowerDVD etc) see the discs as present in the drive?
According to another site, this drive has limited support for BD reading, and was introduced in 2011... It really doesn't seem a candidate for LibreDrive support, but if Mike thinks it can do it with a firmware upgrade, maybe it can.
It would probably be a good idea to get a dump of the existing firmware and forward it to Mike for analysis. It will never do UHD, but there are advantages to LD in non-UHD drives.
Blackened2687
Post by Blackened2687 »
CH30N is an OEM-version of CH12NS30/UH12NS30 - these drives are capable of reading BDXL media, but don't support UHD BD.
Consider it a BD-combo counterpart of old BH16NS40/WH16NS40 drive lineup.
