Are most 4K Bluray main titles split?
davie
Post by davie »
On some Blurays the main titles are a whole file where as I have found on others the movie is split into multiple sections, if a movie is split can MakeMKV be set to extract the whole main title as one? also is teh average 4K Bluray split into multiple files or a single main title?
Re: Are most 4K Bluray main titles split?
Movies are constructed according to the Play Lists (mpls) files on them, using the Transport Stream (m2ts) files on the disk. And yes, MakeMKV constructs them if you select the correct play lists to extract.
davie
Post by davie »
Woodstock wrote: Sun Sep 29, 2019 11:44 pm Movies are constructed according to the Play Lists (mpls) files on them, using the Transport Stream (m2ts) files on the disk. And yes, MakeMKV constructs them if you select the correct play lists to extract.
Thanks for the explanation :)
