X-MEN Dark Phoenix 4k
Unibrowser
#1 Post by Unibrowser » Thu Sep 26, 2019 6:50 pm
Anyone have the correct playlist number yet for the retail 4k version of the movie?
My options are
.800 .801 .802
The segment map on .801 and .802 is 3,61,62
The segment map on .800 is 3,6,62
This is the way
Re: X-MEN Dark Phoenix 4k
#2 Post by Woodstock » Thu Sep 26, 2019 6:59 pm
Which language do you want? English is 800.
Unibrowser
#3 Post by Unibrowser » Thu Sep 26, 2019 7:05 pm
Yes English is what I am after thank you!
This is the way
#4 Post by Woodstock » Fri Sep 27, 2019 3:01 am
The X-Men titles follow the usual "Disney rule". The difference between the 800, 801, and 802 titles are in the opening titles and closing credits. 800 has English, and I can't remember which of the others is Spanish and which is French.
The "Disney rule" is not just titles released under the Disney Studios label; they own several, and use the same rules for mastering disks. Almost always, though, if you see 2 or 3 titles with the same length, and play lists 800, 801, and 802, the rule applies. Checking their segment maps, the main portion will match on all of them.
bkontrarian
#5 Post by bkontrarian » Sat Jun 27, 2020 7:58 am
The only difference is the intro.
00800.mpls (00003.m2ts + 00006.m2ts + 00062.m2ts) will give you the original USA marketed title of just "Dark Phoenix".
00801.mpls or 00802.mpls (00003.m2ts + 00061.m2ts + 00062.m2ts) will give you "X-MEN: Dark Phoenix" which was the marketed title outside of the USA.
