Valkyrie will not copy
wasim274
#1 Post by wasim274 » Sun Sep 26, 2010 6:30 am
The MakeMKV process starts OK. Just over half way through the process just stops. Progress bars stay on screen but everything hangs. Have left it like that for more than an hour before having to terminate. Have tried this 3 times now and have cleaned disk. No blemishes. Any advice would be gratefully received.
setarip_old
Re: Valkyrie will not copy
#2 Post by setarip_old » Sun Sep 26, 2010 5:37 pm
Hi!
In light of the number of similar problems you've had, you might try running a cleaning disc on your Blu-ray drive.
You might also return this disc to the place of purchase in exchange for a new one...
wasim274
#3 Post by wasim274 » Mon Sep 27, 2010 6:09 am
Many thanks have returned offending disk. Am still successfully managing to copy almost all my discs so suspect it's not the drive.
wasim274
#4 Post by wasim274 » Tue Sep 28, 2010 2:32 pm
Update: Replacement disk copied fine. Sorry if it wasted anybody's time.
setarip_old
#5 Post by setarip_old » Tue Sep 28, 2010 9:03 pm
Glad to hear that. It's always gratifying when the simple solutions work ;>}
Lunatik
#6 Post by Lunatik » Mon Oct 18, 2010 11:22 am
Weird part is that I'm having issues dumping the DVD version of this movie. I can extract it to ISO and the ISO will play but something with it MakeMKV just doesn't like it.
setarip_old
#7 Post by setarip_old » Mon Oct 18, 2010 10:46 pm
@Lunatik
Submit a debug log
(You really should have posted in the "DVD Error" sub-forum)
Lunatik
#8 Post by Lunatik » Sun Oct 24, 2010 3:36 am
I wasn't paying attention on which forum I was in. I just did a search for this movie and this thread came up. However it appears that 1.6.2 fixed the problem so its pointless to do a debug log now.
setarip_old
Re: Valkyrie will not copy - RESOLVED
#9 Post by setarip_old » Sun Oct 24, 2010 6:47 am
@Lunatik
Glad to hear your problem's been resolved ;>}
