Can't rip Anna UHD: "Fatal program error occurred"
KENSAI
Post by KENSAI »
I'm trying to rip a Redbox copy of Anna in UHD, using a Libre-flashed drive that has been working great for over a month with all 4K discs, but this disc is basically crashing MakeMKV. Here's a screenshot of what I'm seeing (I had to make the URL below "code" so the forum software wouldn't truncate it):
https://drive.google.com/open?id=1HJQiR4_Fve-udNoN0Uz5ISBDFKE9zfu_
I haven't seen this particular problem before - is there anything I should try?
UPDATE: I tried the same drive and disc connected to my laptop, and it didn't crash, instead giving me an error about the volume key not being available.
MakeMKV v1.14.5 darwin(x64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE BU40N 1.03d" opened in OS access mode.
Using LibreDrive mode (v05 id=866A98CB9C4E)
Saved AACS dump file as /Users/jasondunn/Library/MakeMKV/MKB20_v68_Anna_6AD4.tgz
hedbert
Re: Can't rip Anna UHD: "Fatal program error occurred"
Post by hedbert »
Greetings-
I am experiencing the same error, Failed to Open.
LibreDrive firmware support is not yet available for this drive (id=FFC6EF9102F9)
Saved AACS dump file as /Users/ednelson/Library/MakeMKV/MKB20_v68_Anna_6AD4.tgz
DEBUG: Code 0 at ~z^$s'IWv3oS0Ilo:29396092
DEBUG: Code 0 at ~z^$s'IWv3oS0Ilo:29395172
hedbert
Post by hedbert »
Greetings-
I have submitted my DUMP file.
avenger09123
Post by avenger09123 »
Here is the file created by Anna on the 4k UHD disc for decryption if you don't have it yet so it can be worked by the bossman here.
Drive admittedly spun up so loud I thought it was going bad, it did it about 5 times before it finished the can't be read portion and created the tgz for us to send.
(3.33 MiB) Downloaded 1334 times
hedbert
Post by hedbert »
Greetings
Has anyone had luck with this title yet?
jonghotti
Post by jonghotti »
Anyone know if the key has been made for this bad boy?
hedbert
Post by hedbert »
Greetings
I have not seen anything yet. :(
audioguy
Post by audioguy »
I can't get it to work either. I have two other drives and will try them.
jonghotti
Post by jonghotti »
So this disc is causing a crash on Windows 10 yet rips fine on macOS High Sierra I think I'm at. Sending a log in would probably help.
oddeyeball
Post by oddeyeball »
At the moment I'm able to rip my best buy 4K UHD Anna.
audioguy
Post by audioguy »
I originally purchased 3 drives (all different) to begin my ripping process as I had many hundreds to rip. But, as it turns out, that was a wise decision for another reason. More than I would have thought, when a movie won't rip via one drive, I try another, and 99.9% of the time, that fixes whatever was wrong. I am in the process of ripping Anna now on a drive other than the first one I tried it on and it seems to be working just fine!! (Using Mac OS)
spl147
Post by spl147 »
KENSAI wrote:I'm trying to rip a Redbox copy of Anna in UHD, using a Libre-flashed drive that has been working great for over a month with all 4K discs, but this disc is basically crashing MakeMKV. Here's a screenshot of what I'm seeing (I had to make the URL below "code" so the forum software wouldn't truncate it):
My first reaction is STOP ripping rental discs! Buy them and make backups of your OWN discs
KENSAI
Post by KENSAI »
Hey spl147: for the record, I rip the rental, watch it once, then delete the file. I'm not a content pirate, I'm simply time-shifting the viewing window. :mrgreen:
spl147
Post by spl147 »
KENSAI wrote:Hey spl147: for the record, I rip the rental, watch it once, then delete the file. I'm not a content pirate, I'm simply time-shifting the viewing window. :mrgreen:
I call BS, and that is a stupid waste of time!
KENSAI
Post by KENSAI »
spl147 wrote: Sun Nov 03, 2019 12:16 pm I call BS, and that is a stupid waste of time!
Thank you for your eloquent thoughts on the matter. :lol:
