Converter Subtitles
Petersillien
Converter Subtitles
Post by Petersillien » Sun Sep 22, 2019 8:11 pm
Which converter (MKV -> mp4) would you advice me to use, if I want to find to keep all the subtitle tracks that makemkv was able to keep when I rip a Blu Ray disk?
Thank you.
Re: Converter Subtitles
Post by Woodstock » Sun Sep 22, 2019 10:07 pm
You cannot keep PGS subtitles from a BD rip if you use MP4 as your video container. They are not compatible, and you can only burn one subtitle into the video.
At the very least, you would have to convert the subtitles into a format that is MP4-compatible, and that is not an exact science.
Post by d00zah » Sun Sep 22, 2019 10:38 pm
Another option... rather than conversion, some folk have found it easier to download .srt files from sources like OpenSubtitlesdotorg. Plain text, generally supported by players. Just pick from a blu-ray source & download what others have already converted. YMMV
