MakeMKV problems after reinstall
cpare
#1 Post by cpare » Sun Sep 22, 2019 12:44 am
Decided to add a new set of drives to my Ubuntu box and give it a clean reinstall as it's been a number of years, unfortunately MakeMKV stopped working with the reinstall - I searched the board for suggestions, and saw one suggesting an Admin needed to call MakeMKV, unfortunately that didn't do the trick- any suggestions?
What changed? Lots Unfortunately
  • I Installed a fresh version of Ubuntu Desktop 19.04, before the rebuild I had been on Ubuntu server with a number of upgrades behind the install.
  • I added a new set of WD 4TB Red drives on the SATA ports my CD and BD drives had occupied (3 &4 )
  • I moved the CD and BD to positions five and six on my GA-970A-DS3P (rev. 1.0) motherboard
  • I am sure I dorked around with the BIOS hoping to find a setting that might resolve this.
  • Same CD/BD drives & cables
  • Moving the CD/BD drives back to their original position doesn't seem to help, but they do seem to autodetect and work faster.
  • I even set the country code on one of the drives to see if that might get me working (I was desperate, don't judge me - can I ever revert?)
Output when trying to rip a DVD that I was able to successfully do just a day prior to the reinstall
cpare@Appserver:~$ uname -a
Linux Appserver 5.0.0-29-generic #31-Ubuntu SMP Thu Sep 12 13:05:32 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
cpare@Appserver:~$ makemkvcon -r --cache=1 info disc:9999|grep DRV:|grep BD-RE
DRV:0,2,999,1,"BD-RE ASUS BW-12B1ST   a 1.00","AREA51RAID","/dev/sr1"
cpare@Appserver:~$ sudo makemkvcon --minlength=1800 --decrypt --directio=true mkv disc:0 all /home/cpare/temp/sr1
MakeMKV v1.14.5 linux(x64-release) started
LibreDrive firmware support is not yet available for this drive (id=B540B206A99E)
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN PARAMETER LIST' occurred while issuing SCSI command A30..010C1000E0..0214F65476E654C6168430..0 to device 'SG:dev_21:1'
Drive BD-RE ASUS BW-12B1ST   a 1.00 has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
Title #1 was added (59 cell(s), 1:59:22)
Title #2 has length of 928 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
Title #3 has length of 56 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
Title #4 has length of 35 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
Title #5 has length of 8 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
Title #6 has length of 16 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '4096'
cpare
Re: MakeMKV problems after reinstall
#2 Post by cpare » Sun Sep 22, 2019 1:08 am
One more important thing to add, I am getting a bunch of I/O errors in my logs as well.
20:47:50 kernel: Buffer I/O error on dev sr0, logical block 3726593, async page read
20:47:50 kernel: print_req_error: I/O error, dev sr0, sector 14906372 flags 0
20:47:49 kernel: Buffer I/O error on dev sr0, logical block 2049, async page read
20:47:49 kernel: print_req_error: I/O error, dev sr0, sector 8196 flags 0
20:47:00 kernel: Buffer I/O error on dev sr0, logical block 3726593, async page read
20:47:00 kernel: print_req_error: I/O error, dev sr0, sector 14906372 flags 0
20:47:00 kernel: Buffer I/O error on dev sr0, logical block 2049, async page read
20:47:00 kernel: print_req_error: I/O error, dev sr0, sector 8196 flags 0
20:22:33 kernel: Buffer I/O error on dev sr1, logical block 3726593, async page read
20:22:33 kernel: print_req_error: I/O error, dev sr1, sector 14906368 flags 0
20:22:32 kernel: Buffer I/O error on dev sr1, logical block 2049, async page read
20:22:32 kernel: print_req_error: I/O error, dev sr1, sector 8192 flags 0
