Aladdin (2019) Blu Ray - Failed to open disc error
plym19
#1 Post by plym19 » Sun Sep 15, 2019 2:22 am
Brand new Blu Ray for Aladdin (2019), getting this error when attempting to open with MakeMKV:
Using LibreDrive mode (v05 id=96929CF53B04)
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?zc3Nzc0+5IMxpd...
Saved AACS dump file as /home/plex/.MakeMKV/MKB_v65_Aladdin_(Live_Action)_C61C.tgz
I'm a novice in terms of MakeMKV and decryption. Is there a way to overcome this error, or do I need to be patient in some regard since it's a newer release? Any help is appreciated.
bandit70
Re: Aladdin (2019) Blu Ray - Failed to open disc error
#2 Post by bandit70 » Thu Sep 19, 2019 9:14 pm
I am receiving the same error as well, following along to see if anyone chimes in with a solution.
#3 Post by Woodstock » Thu Sep 19, 2019 10:08 pm
That file needs to be emailed to svq@makemkv.com for analysis, after which the key will be added to the hash table that MakeMKV downloads. It may take a few days.
plym19
#4 Post by plym19 » Fri Sep 20, 2019 3:36 am
I've done this from MakeMKV, following the link provided. Will that cover it or is there something else I would need to send?
plym19
#5 Post by plym19 » Fri Sep 20, 2019 3:38 am
Update: I just restarted MakeMKV and let it download the latest. It's now ripping fine (in progress). Hopefully it works for you now as well.
omk1980
#6 Post by omk1980 » Fri Nov 08, 2019 6:00 am
Anyone have any Atmos audio stutters on this disc? Heard Disney movies were plagued by this bug.
