Anna (2019) - Which Playlist?
dbtayag
#1 Post by dbtayag » Tue Sep 17, 2019 1:38 pm
It's another Lionsgate title with an obfuscated playlist. This is the RETAIL version. Which playlist?
hvnphoto
Re: Anna (2019) - Which Playlist?
#2 Post by hvnphoto » Tue Sep 17, 2019 4:30 pm
00757.MPLS
Steveredrum
#3 Post by Steveredrum » Tue Sep 17, 2019 10:10 pm
00757.MPLS
I agree it worked for me - Thanks
dbtayag
#4 Post by dbtayag » Wed Sep 18, 2019 12:08 am
00757.MPLS
How are you able to find out the right playlist? I tried the process monitor way and it didn't work.
hvnphoto
#5 Post by hvnphoto » Wed Sep 18, 2019 8:55 pm
Title information
Source file name: 00757.mpls
Duration: 1:58:59
Chapters count: 16
Segment count: 15
Segment map: 512,511,513,502,508,515,501,506,509,503,505,507,504,510,514
File name: Anna_t213.mkv
For those interested in the segment map. BDInfo was used to determine correct playlist. Other tools include AnyDVD HD and manual process.
Steveredrum
#6 Post by Steveredrum » Fri Sep 20, 2019 12:07 am
00757.MPLS
With it being a FAKE Playlist beause its a Lionsgate Film [Screen Pass - Playlist Obfuscation] Look For Video On
Youtube using Jack The Lads Tut not easy to do. (Or Let DVDFab Or AnyDVD Do It For You If You Have The Original Film)
dbtayag
#7 Post by dbtayag » Sun Sep 22, 2019 12:55 am
How are you able to determine the correct playlist with BDInfo? Are there any videos able to show me how? I have the program and I was just confused.
hvnphoto
#8 Post by hvnphoto » Sun Sep 22, 2019 11:18 pm
Use Makemkv to backup the disc, thereby, creating the BDMV folder. Use BDInfo to scan the BDMV folder. The correct playlist is at the top. In the case of Anna, playlist 757 is at the top. You can try with other movies as well.
jinx100
#9 Post by jinx100 » Wed Sep 25, 2019 4:28 pm
Any ideas for the RB rental? The Java selected mpls in MakeMKV has an error when Anna and her boyfriend return to their apartment after the car wreck. Shows Anna talking to KGB agent over her friend's body then shows the agent shooting the boyfriend later.
Instantcuddles99
#10 Post by Instantcuddles99 » Wed Sep 25, 2019 10:09 pm
I also want to know if anyone found the correct playlist for the rb?
LG-BDNU40
#11 Post by LG-BDNU40 » Wed Sep 25, 2019 11:39 pm
Which chapter # was out of place?
This time MKV chose Name: Anna (English) which appeared to be correct, start of chapter by chapter, for the RB version.
Comment: FPL_MainFeature
Source file name: 00181.mpls
Duration: 1:58:59
Chapters count: 16
Segment count: 15
Segment map: 512,511,502,513,508,515,501,506,509,505,503,507,504,510,514
File name: Anna-FPL_MainFeature_t00.mkv
Once again BDInfo was wrong, it chose the only 17 chapter playlist placed at the top:
Comment: SPBD Copy Disclaimer Playlist
Source file name: 00705.mpls
Duration: 1:59:59
Chapters count: 17
Segment count: 16
Segment map: 512,3374,509,504,513,501,515,514,506,508,503,505,511,502,510,507
File name: Anna-SPBD Copy Disclaimer Playlist_t08.mkv
I'll hold off watching backup until I can verify correct playlist.
tenjuna
#12 Post by tenjuna » Wed Sep 25, 2019 11:46 pm
757 segment list on the RB version appears the same as the 757 referenced above. I will try that and report back.
EDIT: Redbox 757 appears to be correct.
jinx100
#13 Post by jinx100 » Thu Sep 26, 2019 2:30 am
Nice observation, tenjuna!
I watched it and agree 757.mpls is correct.
reckless75
#14 Post by reckless75 » Fri Oct 04, 2019 3:43 am
I tried the MakeMKV backup method and then used BDInfo, but it still shows 705.mpls as the top playlist. However, I confirmed that 757.mpls is correct. Is there a setting I'm missing in BDInfo that would allow the correct playlist to show up at the top of the list?
oddeyeball
#15 Post by oddeyeball » Fri Oct 04, 2019 10:00 pm
757 appears to be correct for mine too on my Best Buy retail copy. I tried the BDInfo on mine as well and also comes up as 705, that playlist includes a segment that says this cannot be played due to copyright restrictions and you should go buy a disc from retail. So when BDInfo is trying to find the correct list its coming up as a non-legit even though it's reading a retail legit disc. Even using a backup method comes up with the same 705 playlist so whatever the java thing is doing, it's coming up as a non-legit so that playlist is selected.
