Angela's Ashes DVD
wasim274
Angela's Ashes DVD
Post by wasim274 »
Several attempts produce failure. Disk drive is ATAPI iHIS104. (LITE-ON BluRay reader) Regional code has not been changed and is set at 2. Disk is also region 2.
setarip_old
Re: Angela's Ashes DVD
Post by setarip_old »
Hi!
Despite your comments, the following appears to foretell/indicate problematic ripping with this drive:
Drive BD-ROM ATAPI iHOS104 WL0D has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
wasim274
Post by wasim274 »
Yes I had noticed that in the log and that is why I included my comment on it. Curious isn't it? Funny thing is..DVDFab will decrypt it using the same drive but when I try to make MKV from the decrypted file, the same error occurs. Moreover if I use a different drive the same error occurs..so it doesn't seem to be an issue with the drive. Something clever on the disk?
Post by mike admin »
It's not an RPC error. Please find which audio track causes the problem - disable them one by one.
wasim274
Post by wasim274 »
Many thanks for your advice. I tried excluding each audio track. Only when I excluded all audio would it copy. Of course movie useless without audio. Workaround...decrypted using DVDFab, reconstructed DVD using TMPGenc editor then used MakeMKV to get successful result! Bit long winded but it worked perfectly.
