probably just use the bootable windows marty made or the one i recommend in my videoToleedo wrote: Thu Sep 19, 2019 5:18 am Thanks for the link and help. It is appreciated. I am still having an issue though. I downloaded the tools and FW and set up wine to run the .exe (ASUS_ODD) as I am running Linux. I get this error though when installing the FW:
DeviceIoControl Error: Error Code 5
I can't issue command through SPTI
Update Failure #4
I'm guessing I need to do this in a Winodws OS and not through Wine, or is there another reason for this error?
Thanks again.
UHD support
Re: UHD support
Toleedo
Re: UHD support
Thanks. Can I find the bootable windows Marty made in the forum somewhere? I haven't been able to find it, though I swear I saw something about it earlier...
I found this video, is this the one you are referring to?
How to video: https://www.youtube.com/watch?v=Yfpf6HoMMis
Re: UHD support
Marty's is on the bottom here : https://www.makemkv.com/forum/viewtopic ... 16&t=19634Toleedo wrote: Thu Sep 19, 2019 8:39 am Thanks. Can I find the bootable windows Marty made in the forum somewhere? I haven't been able to find it, though I swear I saw something about it earlier...
The other one is on my older video the dosflash one it is also in that post the video that says useful for recovery but don't follow that guide it's the old way
Toleedo
Re: UHD support
Just wanted to thank everyone for the helpful links and advice. Was never able to get the flasher to work through wine on Linux, if anyone ever has let me know what you did.
Ended up buying an adapter and using my windows laptop...if I wasn’t so stubborn about doing it in Linux it would have been a much faster process.
Thanks again!
Thanks again!
troyBORG
Re: UHD support
I'm in the same boat. I can't get Linux to flash the Drive either. When I run the exe it sees the drive, but it just stays at 0% flashing.
I tested and it will yell at me that I have a disc in the drive so I don't know why it doesn't start.
