Anna (2019) - Which Playlist?
dbtayag
Post by dbtayag »
It's another Lionsgate title with an obfuscated playlist. This is the RETAIL version. Which playlist?
hvnphoto
Re: Anna (2019) - Which Playlist?
Post by hvnphoto »
00757.MPLS
Steveredrum
Post by Steveredrum »
hvnphoto wrote:
Tue Sep 17, 2019 4:30 pm
00757.MPLS
I agree it worked for me - Thanks
dbtayag
Post by dbtayag »
00757.MPLS
How are you able to find out the right playlist? I tried the process monitor way and it didn't work.
hvnphoto
Post by hvnphoto »
Title information
Source file name: 00757.mpls
Duration: 1:58:59
Chapters count: 16
Segment count: 15
Segment map: 512,511,513,502,508,515,501,506,509,503,505,507,504,510,514
File name: Anna_t213.mkv
For those interested in the segment map. BDInfo was used to determine correct playlist. Other tools include AnyDVD HD and manual process.
Steveredrum
dbtayag wrote:
Wed Sep 18, 2019 12:08 am
00757.MPLS
With it being a FAKE Playlist beause its a Lionsgate Film [Screen Pass - Playlist Obfuscation] Look For Video On
Youtube using Jack The Lads Tut not easy to do. (Or Let DVDFab Or AnyDVD Do It For You If You Have The Original Film)
dbtayag
Post by dbtayag »
hvnphoto wrote:
Wed Sep 18, 2019 8:55 pm
How are you able to determine the correct playlist with BDInfo? Are there any videos able to show me how? I have the program and I was just confused.
hvnphoto
Post by hvnphoto »
Use Makemkv to backup the disc, thereby, creating the BDMV folder. Use BDInfo to scan the BDMV folder. The correct playlist is at the top. In the case of Anna, playlist 757 is at the top. You can try with other movies as well.
jinx100
Post by jinx100 »
Any ideas for the RB rental? The Java selected mpls in MakeMKV has an error when Anna and her boyfriend return to their apartment after the car wreck. Shows Anna talking to KGB agent over her friend's body then shows the agent shooting the boyfriend later.
Instantcuddles99
Post by Instantcuddles99 »
I also want to know if anyone found the correct playlist for the rb?
LG-BDNU40
Post by LG-BDNU40 »
jinx100 wrote:
Wed Sep 25, 2019 4:28 pm
Which chapter # was out of place?
This time MKV chose Name: Anna (English) which appeared to be correct, start of chapter by chapter, for the RB version.
Comment: FPL_MainFeature
Source file name: 00181.mpls
Duration: 1:58:59
Chapters count: 16
Segment count: 15
Segment map: 512,511,502,513,508,515,501,506,509,505,503,507,504,510,514
File name: Anna-FPL_MainFeature_t00.mkv
Once again BDInfo was wrong, it chose the only 17 chapter playlist placed at the top:
Comment: SPBD Copy Disclaimer Playlist
Source file name: 00705.mpls
Duration: 1:59:59
Chapters count: 17
Segment count: 16
Segment map: 512,3374,509,504,513,501,515,514,506,508,503,505,511,502,510,507
File name: Anna-SPBD Copy Disclaimer Playlist_t08.mkv
I'll hold off watching backup until I can verify correct playlist.
tenjuna
Post by tenjuna »
757 segment list on the RB version appears the same as the 757 referenced above. I will try that and report back.
EDIT: Redbox 757 appears to be correct.
jinx100
Post by jinx100 »
Nice observation, tenjuna!
I watched it and agree 757.mpls is correct.
reckless75
Post by reckless75 »
I tried the MakeMKV backup method and then used BDInfo, but it still shows 705.mpls as the top playlist. However, I confirmed that 757.mpls is correct. Is there a setting I'm missing in BDInfo that would allow the correct playlist to show up at the top of the list?
oddeyeball
Post by oddeyeball »
reckless75 wrote:
Fri Oct 04, 2019 3:43 am
757 appears to be correct for mine too on my Best Buy retail copy. I tried the BDInfo on mine as well and also comes up as 705, that playlist includes a segment that says this cannot be played due to copyright restrictions and you should go buy a disc from retail. So when BDInfo is trying to find the correct list its coming up as a non-legit even though it's reading a retail legit disc. Even using a backup method comes up with the same 705 playlist so whatever the java thing is doing, it's coming up as a non-legit so that playlist is selected.
