Good Evening,
I have just ripped Batman - The Animated Series Series 1 Disc 1 Episode 1. There are three audio tracks identified on MakeMKV, and in the resulting output file. However, these are all identical, audio commentary tracks.
I have made an Unencrypted Backup and this plays normally ( episode audio, no commentary) via VLC. Again, single episode MKV extract from that backup behaves exactly the same as direct from disc ( 3 identical, audio commentary tracks).
I have also tried using the "Default" profile as opposed to my customised one but no change.
Thank you
Batman - The Animated Series UK Bluray
Re: Batman - The Animated Series UK Bluray
"Identified by MakeMKV" - at what point?
If you expand the title as shown in the topic on using Expert Mode, are there 3 separate tracks there? At all tracks selected?
Thanks for your reply! Yes; I expanded the contents fully and there were three tracks, and all selected. I tried to see if there was any discernible different in the info box but there was not.Woodstock wrote: Sun Sep 15, 2019 2:27 am "Identified by MakeMKV" - at what point?
Would a screenshot help at all? I’ve ripped thousands of discs and never came across this before!
Thanks.
**Deleted !!! IGNORE**
Wrote something about DVD, but this is a Blu-ray.
Good Luck
Are there any other audio tracks with different languages?
Good Luck
None; only English??!! Screenshot attached...
UPDATE: Added Media info screenshot from VLC during playing the Unencrypted Backup...
- Screenshot 2019-09-15 at 19.37.54.png (253.58 KiB) Viewed 15885 times
- Screenshot 2019-09-15 at 19.31.01.png (156.13 KiB) Viewed 15886 times
SOLVED!
So I went and checked the other titles... guess what? 3 languages all shown correctly. The first track seems to be duplicate with only directors commentary. I feel slightly stupid but glad its sorted!
Thanks to all who read and contributed....
Great!
That's was my next question. Simply duplicates with other MPLS are on many Blu-rays. F.e. only Japan language tracks are in an extra MPLS. Can be identified very fast by checking the title MPLS Segment Map in the below right MakeMKV window. If the stream segments are the same, the video streams(s) is the same and only the included tracks (audio and/or subtitles) are different.
Good Luck
