Upgrading UHD drive to LibreDrive
ghostrider
Post by ghostrider » Sat Sep 14, 2019 11:24 am
I have a stock LG UH12NS40 drive running f/w 1.00. It works fine in MakeMkv, but I think upgrading it with LibreDrive support would breath new life into it. This is the drive info;
Product: BDDVDRW UH12NS40
Revision: 1.00
Serial number: SIK93G41F014
Firmware date: 2116-02-23 10:42
I need to know what's the best/safest way of upgrading the firmware. I downloaded the link in this thread https://www.makemkv.com/forum/viewtopic ... s40#p76524, but when I try to flash the drive to 1.00-A4, I get this message;
Checksum is mismatched. Drive will go to BOOT mode. Please try again.
The drive still works, so nothing has changed. I don't mind cross-flashing, but advice on the best firmware and/or way to achieve this would be great.
Re: Upgrading UHD drive to LibreDrive
Post by Coopervid » Sat Sep 14, 2019 5:18 pm
BlueMac77
Post by BlueMac77 » Sat Sep 14, 2019 9:21 pm
Revision: 1.00
Hi You may need to check first if your LG UH12NS40 BD Drive is "UHD Friendly" from this Ultimate Guide authored by BillyCar11 https://www.makemkv.com/forum/viewtopic ... 16&t=19634
So far, the UHD Friendly Drives are listed below from the Guide. Also check if your LG Blu-Ray drive is manufactured after 2015
LG WH16NS60, UHD Official Internal 5.25
LG BU40N, UHD Official Internal Slim Sata 9.5mm
LG WH14NS40, UHD Friendly Internal 5.25
LG WH16NS40, UHD Friendly Internal 5.25
ASUS BW-16D1HT, UHD Friendly Internal 5.25
ASUS BW-16D1HT Pro, UHD Friendly Internal 5.25
LG BH16NS55, UHD Friendly Internal 5.25
Buffalo BRUHD-PU3-BK, UHD Official, External Slim 9.5mm USB 3.0-Must use Marty's asus tool to flash
Archgon MD-8107S-U3-UHD, UHD Official, External Slim 9.5mm USB 3.0-Marty
BP60NB10, UHD Official External Slim 9.5mm USB 2.0-Must use Marty's asus tool to flash 8/24/19 or later only
Post by MartyMcNuts » Sun Sep 15, 2019 3:21 am
Revision: 1.00
The OP just wants to add LibreDrive if possible. As @Coopervid mentioned, there is a UH12NS40_1.01_MK firmware available in the MK firmware pack. You could try this firmware with either of the windows flashers.
BlueMac77
Post by BlueMac77 » Sun Sep 15, 2019 8:22 am
Thanks MartyMcNuts for the clarification and heads up. Sorry for the confusion. Good to know the possibility that LibreDrive can be enabled on certain models.
ghostrider
Post by ghostrider » Sun Sep 15, 2019 2:38 pm
Revision: 1.00
Thanks. So, whilst mine doesn't appear on that list, I believe others have used this drive successfully. MakeMkv reports the drive as LibreDrive capable, but not enabled. By 'UHD friendly' do you mean can it read UHD discs? Yes it can, I've backed up a couple of UHD discs using it.
Post by Coopervid » Sun Sep 15, 2019 5:04 pm
@ghostrider,
If you download the MK firmware zip-file in my post you will find the 1.01 firmware for your drive.
ghostrider
Post by ghostrider » Mon Sep 16, 2019 8:32 pm
Revision: 1.00
Thanks for the feedback. I've downloaded the MK pack, and this did have 1.01 of the firmware for my UH12NS40. I've used the standard flash tool, and this time it worked and flashed without an error. After a reboot MakeMkv is now reporting the new firmware and that the drive is Libredrive ready. Just doing a test backup now, but all looking good. Blu-Ray and UHD's read ok using LibreDrive fw. Happy days!
Post by Coopervid » Mon Sep 16, 2019 10:05 pm
Good to hear that you are in business now! :D
Post by MartyMcNuts » Mon Sep 16, 2019 11:28 pm
Good stuff ghostrider. Glad it worked out 👍😁
BlueMac77
Post by BlueMac77 » Tue Sep 17, 2019 7:08 pm
Great to know that your optical drive worked out perfectly. Sorry for the previous post on the guide that may be confusing. Enjoy and have Fun ripping those 4K UHDs. :)
