The Matrix
Disposable9
The Matrix
Post by Disposable9 » Fri Sep 13, 2019 6:35 pm
I'm trying to rip The Matrix and it's failing. I've ripped many other UHD movies and never had any problems?
OS device name: G:
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.00
Serial number: <deleted>
Firmware date: 2115-12-09 11:47
Bus encryption flags: 1E
Highest AACS version: 70
Harware support: Yes
Firmware support: No
Firmware version: 3.00
Disc Information
Label: THE_MATRIX
Timestamp: 2018-04-05 18:01:26
Data capacity: 64.83 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
MakeMKV v1.14.5 win(x64-release) started
LibreDrive firmware support is not yet available for this drive (id=F8B3C9080B22)
Saved AACS dump file as C:\Users\<deleted>/.MakeMKV/MKB20_v61_The_Matrix_19A7.tgz
Any help would be appreciated.
Re: The Matrix
Post by Billycar11 » Fri Sep 13, 2019 10:48 pm
Thats a weird one you have the right fw but makemkv is not enabling libredrive
in that state i dont think any UHD disk will work
try deleting privatedata.tar in make mkv data directory and try again
Disposable9
Re: The Matrix
Post by Disposable9 » Sat Sep 14, 2019 9:40 am
I successfully ripped The Dark Knight trilogy UHDs last night, so I think the problem is specific to this disc.
I tried renaming "_private_data.tar" to "_private_data (backup).tar" and ripping the disc again, it failed but this time I got a slightly different log:
Downloading latest SDF to C:\Users\<deleted>/.MakeMKV ...
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom1'
Downloading latest HK to C:\Users\<deleted>/.MakeMKV ...
I'm going to email the MKB20_v61_The_Matrix_19A7.tgz file.
Disposable9
Re: The Matrix
Post by Disposable9 » Sat Sep 14, 2019 9:44 am
Just tried it again with debug logging on:
Debug logging enabled, log will be saved as C:\Users\<deleted>/MakeMKV_log.txt
DEBUG: Code 0 at E"`0L*bjuZ+[XW`":29396092
DEBUG: Code 0 at E"`0L*bjuZ+[XW`":29395172
Re: The Matrix
Post by Billycar11 » Sat Sep 14, 2019 10:19 am
Disposable9 wrote: Sat Sep 14, 2019 9:44 am Just tried it again with debug logging on:
just for fun try another UHD disk it is complaining about libredrive not an unknown volume key this is quite weird
might have to try the old uninstall and reinstall reboot if you haven't
Disposable9
Re: The Matrix
Post by Disposable9 » Sat Sep 14, 2019 10:38 am
So this is the output I get when I open the Batman Begins UHD disc.
File 00009.mpls was added as title #0
Title #00010.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.mpls has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00033.mpls was added as title #1
Title #00002.mpls has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00020.mpls is equal to title 00033.mpls and was skipped
Title 00036.mpls is equal to title 00033.mpls and was skipped
Title #00000.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
I'll try doing and uninstall / reboot / reinstall and see if it makes any difference.
Disposable9
Re: The Matrix
Post by Disposable9 » Sat Sep 14, 2019 11:01 am
So uninstall / reboot / reinstall didn't fix anything.
If it helps, I found the MakeMKV_log.txt file.
Debug log started at Sat Sep 14 10:58:09 2019 , written by MakeMKV v1.14.5 win(x64-release)
001005:0000 MakeMKV v1.14.5 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\<deleted>/MakeMKV_log.txt
SDF v060: ASUS_BC-12D2HT_3.00_211512091147_SIK9AG22I281
001011:0000 LibreDrive firmware support is not yet available for this drive (id=F8B3C9080B22)
DEBUG: Code 2317353437 at !BYd\|M dT`ziq.g:121264096
DEBUG: Code 0 at !BYd\|M dT`ziq.g:121264119
DEBUG: Code 1 at !BYd\|M dT`ziq.g:121264119
DEBUG: Code 2 at !BYd\|M dT`ziq.g:121264119
DEBUG: Code 3 at !BYd\|M dT`ziq.g:121264119
DEBUG: Code 4 at !BYd\|M dT`ziq.g:121264119
DEBUG: Code 5 at !BYd\|M dT`ziq.g:121264119
DEBUG: Code 2317353437 at !BYd\|M dT`ziq.g:213132652
DEBUG: Code 0 at %.rR&vsq2cI<A6cT:213141530
DEBUG: Code 0 at E"`0L*bjuZ+[XW`":29400669
DEBUG: Code 2147483648 at %.rR&vsq2cI<A6cT:213132974
DAFD=PAAAADAAAAEABDQkEHgACAQ==
DCE=ZyUiKXWm+lYimlKsaXoW9h/2YqxWfu30FDz0fwvaCwSx90Q690ojGkMmykpkL23E2vIMQ+n7hYP3h+Lgsq2fVcmQ4aLcmy34OuuOfnzWqoqi5A4t+4N8hiWk3TMxV4O/VAhUwtJCkkGi6zFzLPtMP3BklR+npdi8Wg==
DCE=MBKNt6S9SxVGkd4dgb+I6CNwcrxZQ6C/AMQyKN1AmB5BnWhNgrPeh4NZ6ZQHlgZugo6Lx+4zMBCvNTeXSNhO+I5pIeGeE3UnrV4RgVFaes5ghL9+0TFYNVVC+u77JT7HESAwfkG5N1L4J+zlySk5BLUoiDobtpOqJA==
003332:0000 Saved AACS dump file as C:\Users\<deleted>/.MakeMKV/MKB20_v61_The_Matrix_19A7.tgz
003346:0000 LibreDrive compatible drive is required to open this disc - video can't be decrypted.
001003:0020 DEBUG: Code 0 at E"`0L*bjuZ+[XW`":29396092
001003:0020 DEBUG: Code 0 at E"`0L*bjuZ+[XW`":29395172
Application exited at Sat Sep 14 10:58:59 2019
Re: The Matrix
Post by Billycar11 » Sat Sep 14, 2019 11:09 am
Hhmm okay well it's weird that it still says no libredrive support on 3.00 but works for Batman I guess 3.00 on your drive does not support libredrive didn't know that the best thing to do then is to flash the mk version for your drive and then it should work
dillspooch
Re: The Matrix
Post by dillspooch » Sat Sep 14, 2019 5:46 pm
For what it's worth I'm trying to use MakeMKV on The Matrix (4K UHD boxset trilogy), and am getting the following...
Downloading latest SDF to D:/Users/Mike/Videos ...
Using LibreDrive mode (v05 id=067EFCA8EA7E)
Saved AACS dump file as D:/Users/Mike/Videos/MKB20_v61_The_Matrix_19A7.tgz
OS device name: E:
Product: BD-RE BH16NS55
Revision: 1.02
Serial number: KLEIAPG5051
Firmware date: 2115-12-11 14:40
Highest AACS version: 66
Firmware version: 1.02
Disc Information
Label: THE_MATRIX
Number of layers: 3
This is the first UHD it couldn't handle. Is there anything I can do?
Re: The Matrix
Post by Coopervid » Sat Sep 14, 2019 6:23 pm
rui-no-onna
Re: The Matrix
Post by rui-no-onna » Sat Sep 14, 2019 6:36 pm
dillspooch wrote: Sat Sep 14, 2019 5:46 pm Saved AACS dump file as D:/Users/Mike/Videos/MKB20_v61_The_Matrix_19A7.tgz
Email the AACS dump and wait for it to be supported.
st4evr
Re: The Matrix
Post by st4evr » Sat Sep 14, 2019 8:02 pm
To be more clear, your error is not related to the one the OP is getting. Forum search function works, use it. That particular error has been discussed hundreds of times already and how to proceed.
https://www.makemkv.com/forum/search.ph ... mit=Search
dillspooch
Re: The Matrix
Post by dillspooch » Tue Sep 17, 2019 7:22 am
I tried it again last night, and for some reason, it worked. Why would that be?
I used the forum search and felt like I was drowning in a sea of answers. Sometimes one needs a little help. I appreciate the assistance.
rui-no-onna
Re: The Matrix
Post by rui-no-onna » Tue Sep 17, 2019 2:10 pm
dillspooch wrote: Tue Sep 17, 2019 7:22 am I tried it again last night, and for some reason, it worked. Why would that be?
New disc, not yet supported until someone emails Mike the AACS dump so he can extract the key and add to the database.
Most times, reading the first post on pinned topics already gives you the answer.
https://www.makemkv.com/forum/viewtopic ... 12&t=16765
Disposable9
Re: The Matrix
Post by Disposable9 » Wed Sep 25, 2019 9:20 pm
An update on this, I returned The Matrix Trilogy and got a replacement.
The Matrix and The Matrix Reloaded have now successfully ripped.
The Matrix Revolutions fails to open with the following log:
Debug log started at Wed Sep 25 21:13:12 2019 , written by MakeMKV v1.14.5 win(x64-release)
SDF v060: ASUS_BC-12D2HT_3.00_211512091147_SIK98G238195
DCE=FJoeZ1uCifAGBMk5dOfOEx/cT/wte1k5EvqFaAJOJXFFzyYQ6rcNYCdgSDbniXKP2moV6ceLMpVxU4eDGwQAstjxHbFwHIcrJmhuHwUcdg4VNMsTxi+i9lDRPytqT2/KfVNWBt7uXj+D7p8ot/hcbRFBGyatS7e+LA==
002004:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom1'
DEBUG: Code 0 at p5?Je;AX_`G;i"o:D:213130306
001003:0020 DEBUG: Code 0 at -Ra^nKZ}<\yekbuFBR:29396552
001003:0020 DEBUG: Code 0 at -Ra^nKZ}<\yekbuFBR:29394275
DCE=1Hi/Dlo3nKsKz3+HcSf5xIrBo88bcjZzlI3v+r221lWhinq4jCjLcQb4wJeGk30O834cLHwRzy5syKAVnq4gSPA4sK7bndRZHYcM39qsdqkJtIU5LFtP89epqK5iT2Z5MZnr6Mide5xiWkPOGY2Tyns4JN+pPO6qbQ==
DCE=wcJwdKuDIKRpCb4u/BkgpQHNLAXcOb03e7Tab8N1M3leUV+Euoh0YrZiW6Du9aU8B6Fw7woE4EurKS9DSHvj52Kl4kS97VGj5hadizQY5z4IO5BSZHUWfv7IDWWlZBVBEVImBxF8/4kmlh8mw59PLa/vCtXMr8mhHA==
003332:0000 Saved AACS dump file as C:\Users\<deleted>/.MakeMKV/MKB20_v65_The_Matrix_Revolutions_4E29.tgz
Application exited at Wed Sep 25 21:17:02 2019
I've emailed MKB20_v65_The_Matrix_Revolutions_4E29.tgz to svq@makemkv.com
