So I ripped a few movies (no issues) but when when I attempt to play back on AppleTV 4k using Plex I get the attached errors. I also have HandBrake but unclear what is the best conversion protocol. Just the preset AppleTV 4k protocol?
AppleTV and hevc files
rui-no-onna
Re: AppleTV and hevc files
I highly recommend using Infuse Pro for playback. It can connect to Plex Media Server and has built-in support for various container formats and codecs including MKV, TrueHD, DTS, etc.
My AppleTV 4K is on wired gigabit and MakeMKV rips play perfectly on Infuse Pro. No transcoding required. I doubt many servers have the horsepower for brute-force, or CPU for hardware assisted decode/encode of 4K HEVC.
On HandBrake, presets are designed so videos play natively on the target device so the AppleTV 4K preset should work fine. Depending on your PC, might take a long while to encode, though.
jefftr66
Yeah I installed Infuse last night and it could play one of the files. Just annoying I need another app....
Not sure how long an encode takes..cause it failed.
sgarbsch
I tried Infuse 6 with a 4K MKV to a non 4K Apple TV. Was the reason it was lagging because without a 4K ATV / projector yet, it had to convert? I’m basically just trying to get the right set up so that when I get my protector installed and 4K Apple TV, I’m ready to go. This would let me know that with a 4K Apple TV and projector, I wouldn’t have this issue with Infuse. Thanks!
anothermkvuser
YES = 4K MKV - to 4K Apple Tv with Infuse 6.3 Pro = works great.
SMB network, ExFaT Formatted Drive on Network on Synology Router with SMB + AFP enabled for LAN.
No need to Transcode. Leave files in MKV.
