Hellboy 2019
santa73
Hellboy 2019
#1 Post by santa73 » Tue Aug 27, 2019 5:26 am
dump sent to svq@makemkv.com
mizu_ger
Re: Hellboy 2019
#2 Post by mizu_ger » Tue Aug 27, 2019 8:36 am
I've sent in the dump for the UK UHD edition too.
mizu_ger
Re: Hellboy 2019
#3 Post by mizu_ger » Wed Aug 28, 2019 7:07 pm
When makemkv tries to process my disk I get the following message in the status window:
DEBUG: Code 2399334402 at }yJ2^mTS!\xYjfa7w:213133733
DEBUG: Code 2399334402 at }yJ2^mTS!\xYjfa7w:29397219
Saved AACS dump file as C:\Users\XXX/.MakeMKV/MKB20_v68_Hellboy_0020.tgz
DEBUG: Code 0 at SYpXh>1]9aM.=fv`:29396092
DEBUG: Code 0 at SYpXh>1]9aM.=fv`:29395172
What do these debug codes mean? Do they indicate a problem reading the disk, or do i just need to wait for it to be added to the database?
mizu_ger
Re: Hellboy 2019
#4 Post by mizu_ger » Sat Aug 31, 2019 8:39 am
Working now. Backed up my disk with no problems
ayates84
Re: Hellboy 2019
#5 Post by ayates84 » Thu Sep 05, 2019 4:41 pm
Anyone know how I can rip this blu-ray? I've searched the forums, but all of the suggestions I have found have not helped. There are hundreds of titles showing on the disc, but I can't figure out which one I need to correctly rip the film!
darcym
Re: Hellboy 2019
#6 Post by darcym » Mon Sep 09, 2019 8:20 am
just to bump this, I have the same question, I see 30+ titles all the same size.
I picked the first one at random and ripped and then encoded it - when I watched the playback, the first half of the film is fine, the second half of the film is out of sequence as if the chapters are jumbled when I looked at the raw mkv file that makemkv created, it's the same in the file the first half is fine - but there are a few subtle bits out of sequence, but when it gets to the fight in the church it's really out of sequence, how can I rip this cleanly
darcym
Re: Hellboy 2019
#7 Post by darcym » Mon Sep 09, 2019 3:00 pm
sorry - I posted this in the UHD section, my problem is on the bluray not UHD, sorry for the incorrect information
smartieyoung
Re: Hellboy 2019
#8 Post by smartieyoung » Thu Sep 12, 2019 12:16 am
I just decrypted hellboy sucessfully on my computer,it took about an hour.still cannot believe my bluray drive is still working ive put over 100 uhd discs through it.im about to try rocketman uhd as well.
smartieyoung
Re: Hellboy 2019
#9 Post by smartieyoung » Thu Sep 12, 2019 6:04 pm
I was able to decrypt Hellboy US version UHD disk without any problems,It took me a little longer then usual to decrypt but the end result seems to be a fully intact copy.I have yet to turn it into a mkv file but i will do that when I feel up to it. :)
