John Wick: Chapter 3 - Parabellum
hvnphoto
Re: John Wick: Chapter 3 - Parabellum
Post by hvnphoto »
Gojira74 wrote: Wed Sep 11, 2019 8:58 pm
hvnphoto wrote: Wed Sep 11, 2019 8:07 pm Have you guys tried running the BDMV file through BDInfo to get the correct playlist? Use Makemkv in backup mode to get the BMMV file then run it through BDInfo to display the playlist.
That's not a method I am familiar with.
While the blu-ray disc is inside the drive open Makemkv and go to file, backup. Check decrypt disc if not already then proceed with the backup process. Makemkv will create a BDMV file.
Use BDInfo to navigate to the BDMV file which will then display the correct playlist. BDInfo works best in Windows. Latest version is 0.7.5.5.
There is a version for Mac but it is rather useless. For Mac users, right click on BMDV and choose "show contents" to see what is inside the file.
moviechamp1859
Post by moviechamp1859 »
Wanted to note that I had the RB copy of the movie and although my makemkv was listing 965 as FPL_MainFeature, i decided to go with 429. I watched the entire movie afterwards and can confirm that was the correct segment.
JabbaDHutt
Post by JabbaDHutt »
I don't know why I didn't think of this before but each one of the numbers is a track # so I thought I should just load the movie and skip to each track to identify how it starts and then take a random burn, notating what the burn shows the track sequence to be and then I can identify which track is the correct track each time. There are only 16 chapter on these movies so it's simply a matter of watching a few times to ensure you have the correct sequence and then you find the correct one with the right sequence.
I don't know why I didn't think of this earlier when I was frustrated with JW1 and JW2 but this hopefully should make it easier.
Thoughts??
Mysus456
Post by Mysus456 »
hvnphoto wrote: Thu Sep 12, 2019 12:26 am
I downloaded 0.7.5.5, and had already backed up disk unencrypted. I opened BDInfo and browsed to the backed up directory under source BD-ROM.
Searching BMDV, I see 2 BMDV Folders (1) backup directory root and (2) is .\MAKEMKV\MEXT\
Also, there are index.bdmv, MovieObject.bdmv, id.bdmv (2 of them) sound.bdmv
Mysus456
Post by Mysus456 »
mellofone wrote: Wed Sep 11, 2019 10:14 pm
Mysus456 wrote: Wed Sep 11, 2019 10:09 pm
I may be missing something, but I downloaded and tried to see how this would help but it was not obvious to me.
My MakeMKV was listing 434 as the FPL_MainFeature. The root of the disk structure labeled it retail.
Source information
Type: Blu-ray disc
Name: John Wick 3: Parabellum (English)
Comment: BD-130923_JohnWick3_Retail
So, perhaps retail and rental disks make it into the Kiosks?
How do you know if the library scene is wrong? Is there a target timeline to view and test?
Because JW was already fighting someone, and in the next segment he was just meeting him.
Confirming 00434 BAD, sequence:
WRONG Segment map: 514,502,517,506,505,511,508,516,519,503,520,512,510,504,507,518,509,515,501
Mysus456
Post by Mysus456 »
MicTx wrote: Wed Sep 11, 2019 10:59 pm Just done a run through and makmkv shows this as the FPL_MainFeature
504,512,509,511,518,506,514,519,505,516,507,520,510,502,508,503,501,515,517 - 00396.mpls
but after looking it looks like this is the correct one for me.
504,512,509,511,518,514,506,519,505,516,507,520,510,502,508,503,501,515,517 - 00444.mpls
I spot checked it against the DVD and the time codes look the same.
All the play lists start with 504 and end with 517.
Amazon preorder Blu-ray - DVD - Digital.
All mpls files on my BD start with segment 514 and end 501.
Looking back this obfuscation is working: just from page 1:
hvnphoto: seg=504...517 mpls=00444
mgadbois: seg 514...501 mpls 00444
ChrisCaPWN: seg: 514...501 mpls 434
manual - 514...501 mpls=965
jeflatt : seg=518...517 mpls= 444
deathtical
Post by deathtical »
Hey guys,
I got my copy from Amazon today. I was able to rip the UHD disc with no issues. However, when I try to rip the BR I get this...
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?vr6+vr65BUVagK...
Saved AACS dump file as C:\Users\James/.MakeMKV/MKB_v70_John_Wick_3-_Parabellum_98A2.tgz
I clicked on the link but there was no option to provide the log file. Here is a link to it...
https://drive.google.com/open?id=1WHbcO ... oqvtw4Hh3A
EDIT: Disregard. I updated from 1.14.3 to 1.14.5 and it's working fine now.
hvnphoto
Post by hvnphoto »
Mysus456 wrote: Thu Sep 12, 2019 2:26 am
Choosing the first BMDV folder should display the playlist as this contains the movie. You should see the Stream folder inside BMDV. The Stream folder contains the segments of the movie if obfuscation is used.
jintadhee
Post by jintadhee »
I want to confirm that the correct play list file of one redbox BluRay is 00965.mpls
The 000434.mpls which flagged as title00 for this disc is not correct.
00965: 514 506 517 502 505 511 508 516 519 503 520 512 510 507 504 518 509 515 501
00434: 514 502 517 506 505 511 508 516 519 503 520 512 510 504 507 518 509 515 501
There are two short sections swapped in the 00434.mpls
I also did confirm by watching the movie at the time calculated from the mpls file.
Hopefully this helps those looking for the right play list file. :D
Mysus456
Post by Mysus456 »
hvnphoto wrote: Thu Sep 12, 2019 4:44 am
I still get 100s of playlist files. I select the bdmv\stream dir and it goes back to root.
schmegory
Post by schmegory »
srteach wrote: Wed Sep 11, 2019 5:12 am
jeflatt wrote: Tue Sep 10, 2019 7:29 pm The process monitor worked! Here is the correct mpls for the Best Buy Blu Ray/DVD/Digital combo...
Title information
Source file name: 00957.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 518,512,514,510,515,506,520,511,516,505,501,504,502,519,507,508,509,503,517
File name: John Wick 3- Parabellum_t369.mkv
Found this to be correct by manual correlation method. BluRay purchased at Walmart
Weird! I also purchase mine at WM and don't have 00957 as an option.
rui-no-onna
Post by rui-no-onna »
Same for my Walmart InstaWatch 4K+Blu-ray set.
Ugh, wonder how many different Blu-ray disc masters they have for this. Thankfully, the 4K disc doesn't seem to have this obfuscation.
LG-BDNU40
Post by LG-BDNU40 »
..and another RB version. All my my M2TS begin with 510 and end with 506. Looks like Lion G just re numbered the M2TS streams for different playlist.
Title information
Comment: FPL_MainFeature
Source file name: 00921.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 510,502,505,511,512,501,516,519,508,507,514,515,509,518,503,504,520,517,506
File name: John Wick 3- Parabellum-FPL_MainFeature_t18.mkv
and for BDinfo fans:
sneaky no?
hvnphoto
Post by hvnphoto »
LG-BDNU40 wrote: Thu Sep 12, 2019 4:44 pm
sneaky no?
Can you please show the Playlist File section? Thanks.
LG-BDNU40
Post by LG-BDNU40 »
hvnphoto wrote: Thu Sep 12, 2019 5:02 pm
sneaky no?
Yes, BDinfo chose this:
Title information
Source file name: 00298.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 510,511,502,505,512,515,514,504,516,509,519,503,508,507,517,501,520,518,506
File name: John Wick 3- Parabellum_t134.mkv
I originally posted wrong BDinfo segments for 298.mpls
After time to view, both the main and BDinfo versions wacked with out of place segments. Sorry to waste anyone's time...
