John Wick: Chapter 3 - Parabellum
nick2421
Re: John Wick: Chapter 3 - Parabellum
#46 Post by nick2421 » Wed Sep 11, 2019 12:50 pm
RB 00434.mpls is not correct. Library scene all messed up.
mellofone
#47 Post by mellofone » Wed Sep 11, 2019 1:09 pm
Gojira74 wrote: Wed Sep 11, 2019 5:49 am Weird question, but did you watch the rest of the movie for 275 or did you stop after the library scene? If that was the only error in that section it would help to narrow it down in a manual way.
Amazon retail bluray, tried 275. It was messed up at the library, and then messed up again when he showed up to the Russian ballet theater, so I gave up.
ssbrian
#48 Post by ssbrian » Wed Sep 11, 2019 1:11 pm
RB Main Feature 434 has library scene out of sequence with latest Java and Makemkv. 965 shows in procman and sequence is correct.
NeoCortex
#49 Post by NeoCortex » Wed Sep 11, 2019 1:36 pm
I just wanted to say that I just checked the library scene (and just the library scene) for RB 429 and it was correct on my disc. So it looks like there might be two different RB discs out there. 965 is correct if it's available, otherwise go with 429.
liquidstate
#50 Post by liquidstate » Wed Sep 11, 2019 3:38 pm
Just verified RB 0429 as earlier posted and can confirm from beginning to end everything was in order.
liquidstate
#51 Post by liquidstate » Wed Sep 11, 2019 4:05 pm
-t-bone- wrote: Wed Sep 11, 2019 3:55 am Seems like 429 for RB worked for me.
Name: John Wick 3: Parabellum
Source file name: 00429.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 510,511,502,505,512,501,519,516,508,514,507,515,518,503,509,504,520,517,506
File name: John Wick 3- Parabellum_t167.mkv
Just Confirmed - Correct segment for RB
ghostman_pfa
#52 Post by ghostman_pfa » Wed Sep 11, 2019 4:36 pm
RB US - With MakeMKV I got 921 as Main Feature. Watched first 10 minutes and it seemed right.
mscroggi
#53 Post by mscroggi » Wed Sep 11, 2019 5:08 pm
My disc doesn't have any of the proposed titles - 965 429, 921, or 957.
It's the 4k Ultra / BR bundle
Gojira74
#54 Post by Gojira74 » Wed Sep 11, 2019 7:51 pm
mscroggi wrote: Wed Sep 11, 2019 5:08 pm My disc doesn't have any of the proposed titles - 965 429, 921, or 957.
I gave up and rented it from RB and used 429. The extra couple bucks was worth my time.
hvnphoto
#55 Post by hvnphoto » Wed Sep 11, 2019 8:07 pm
Have you guys tried running the BDMV file through BDInfo to get the correct playlist? Use Makemkv in backup mode to get the BMMV file then run it through BDInfo to display the playlist.
Gojira74
#56 Post by Gojira74 » Wed Sep 11, 2019 8:58 pm
hvnphoto wrote: Wed Sep 11, 2019 8:07 pm Have you guys tried running the BDMV file through BDInfo to get the correct playlist? Use Makemkv in backup mode to get the BMMV file then run it through BDInfo to display the playlist.
That's not a method I am familiar with.
Mysus456
#57 Post by Mysus456 » Wed Sep 11, 2019 10:09 pm
I may be missing something, but I downloaded and tried to see how this would help but it was not obvious to me.
My MakeMKV was listing 434 as the FPL_MainFeature. The root of the disk structure labeled it retail.
Source information
Type: Blu-ray disc
Name: John Wick 3: Parabellum (English)
Comment: BD-130923_JohnWick3_Retail
So, perhaps retail and rental disks make it into the Kiosks?
How do you know if the library scene is wrong? Is there a target timeline to view and test?
mellofone
#58 Post by mellofone » Wed Sep 11, 2019 10:14 pm
Mysus456 wrote: Wed Sep 11, 2019 10:09 pm
Source information
Type: Blu-ray disc
Because JW was already fighting someone, and in the next segment he was just meeting him.
MicTx
#59 Post by MicTx » Wed Sep 11, 2019 10:59 pm
Just done a run through and makmkv shows this as the FPL_MainFeature
504,512,509,511,518,506,514,519,505,516,507,520,510,502,508,503,501,515,517 - 00396.mpls
but after looking it looks like this is the correct one for me.
504,512,509,511,518,514,506,519,505,516,507,520,510,502,508,503,501,515,517 - 00444.mpls
I spot checked it against the DVD and the time codes look the same.
All the play lists start with 504 and end with 517.
Amazon preorder Blu-ray - DVD - Digital.
Dustin66
#60 Post by Dustin66 » Wed Sep 11, 2019 11:56 pm
Title information
Source file name: 00965.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 514,506,517,502,505,511,508,516,519,503,520,512,510,507,504,518,509,515,501
File name: John Wick 3- Parabellum_t380.mkv
Redbox version using Process monitor.
